Aleph-X builder's thread.
Old 20th November 2006, 08:32 PM   #1131
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
As you go to the higher voltage parts the transconductance
decreases (higher voltage doping gives greater resistivity)
and you subjectively see more bottom, but somewhat at
the expense of the top end. This is reasonably subtle, but
is exacerbated by using IR input P channel devices. For this
reason, the Harris or Fairchild input P channel parts are even
more important.
Old 21st November 2006, 04:28 AM   #1132
carpenter is offline carpenter  United States
Paper mache horn fabricator
carpenter's Avatar
The 044's sound ever so slightly darker, but still ever so resolved.
That's interesting, Terry. I couldn't quite put my finger on it, but my ZV7-T sounds quite different with the 044's vs. the 244's. A bit more subdued, but very sweet. The top-end isn't glaring anymore.
Here's to darker,
John
I enjoy audio so much that I constructed a web site. I share my ideas at: www.inlowsound.com
Old 23rd November 2006, 12:18 PM   #1133
yup is offline yup
Exclamation ???
Are we saying two different things here???
It sounds like a lot of folks are claiming the 044 are "a bit darker", however, based on what Nelson just said the higher voltage parts (144's & 244's) should be the ones that sound darker.
I am somewhat confused... Which is it?
Thanks,
Jeff
Old 23rd November 2006, 03:07 PM   #1134
carpenter's Avatar
yup, just reporting what my ears hear...
John
Old 23rd November 2006, 06:41 PM   #1135
Nixie is offline Nixie  Canada
Banned
Sounds like we need some blind testing here
Old 26th November 2006, 07:38 PM   #1136
eapavant is offline eapavant  United States
I am wondering if anyone can help me. I have a problem with my aleph-x. Here is the schematic. I am using 4 devices total per side. 22.5vdc and about 2.5 amps per side. It seems to bias up where it should, and I have about 4.5v on r1 and r51. I can get dc down to a ok level and every thing seems to be ok. The problem is when I give it a signal, I can just barley hear sound out of a speaker. I thought the output protection might be on but the bipolars are off. Any ideas where to look next?
Old 26th November 2006, 08:10 PM   #1137
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
Hmm..hard to tell. You have a scope?
/Hugo
Old 26th November 2006, 08:37 PM   #1138
bach2800 is offline bach2800  Canada
Send a message via MSN to bach2800
I had the same problem and the BC550 were reversed.
Thierry
Old 26th November 2006, 09:58 PM   #1139
I do have a scope. And I will check the bc550c. I don't think they are in backwards.
Old 26th November 2006, 10:06 PM   #1140
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
check all resistor values and positions
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Aleph-X builder's thread.Hide this!Advertise here!
Copyright ©1999-2017 diyAudio
