Trying to build Aleph 30 - diyAudio
Old 1st December 2015, 01:19 PM   #1
Default Trying to build Aleph 30
I ever build this amp but lost after shifting house. I also forgotten many things about electronics in time. I had arranged parts for Aleph 30 including Transformer 18-0-18, signal generator and cheap Dso138 Oscilloscope.
I have completed one channel test board. it showing output 23v DC (somethings wrong), mesured Gnd + Output with multimeter DC Voltage no short in input.
I didn't use pot on R8 as it indicated 10m ohm should be fine if two input are not well matched. I have used matched mosfets. still checking for any wrong doing. Thanks
Old 1st December 2015, 02:21 PM   #2
DC out 23v
There must be errors on parts.
Broken parts or maybe polarity reverse.
Double check, especially for the ztx and caps.
Old 2nd December 2015, 09:26 AM   #3
Thanks. I found the problem. Mosfet IRF9610 damaged by soldering iron as it is not Grounded. How can i avoid such incident? any tips for soldering?
Old 2nd December 2015, 11:51 AM   #4
wdecho is offline wdecho  United States
You will find many good video's on youtube on soldering. The main thing to remember is that whatever you are soldering has to be hot enough to melt the solder. You do not melt solder onto the parts. The same can be said about welding or brazing. Clean your tip and apply a touch of solder to the tip every time is also good advice to get a good heat transfer.
Old 2nd December 2015, 03:12 PM   #5
When soldering a sensitive parts,
I will always disconnect the solder ac plug.
Then quickly soldering the parts while it is still hot.
Old 21st December 2015, 08:13 AM   #6
having problem. at first, I was using BC550 instead of MPSA18 and it was fine. i was thinking that should use MPSA18 as original diagram so purchased from online MPSA18 and changed the BC550. now it is showing output as a -volt. Thanks.
Old 21st December 2015, 10:47 AM   #7
The MPSA18 has a different pin-out than the BC550. (You need to
turn it around compared to the BC550.) Is it possible you did not
account for that?
Dennis
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old 21st December 2015, 11:56 AM   #8
Thanks. I already checked Mpsa18, it is properly placed. across R123 should be 0.13v as design but mine is 0.03v. something is wrong.
Old 21st December 2015, 01:33 PM   #9
Is this the schematics you are referring to?
http://www.zen183332.zen.co.uk/Aleph/Aleph30.pdf
What voltages are you getting across say R118, R126 and R9? Any other voltages
seem weird?
Dennis
- NP 2002
Old 22nd December 2015, 04:16 AM   #10
voltage
R118 -0.38 (gnd to R118)
R126 +0.023 (-v rail to R126)
R9 3.75 (across)
Thanks.
FS: Pass PCB's (F5, Aleph AJ-X, mini Aleph or Aleph 30) nycavsr2000 Swap Meet 2 2nd January 2015 11:15 PM
Aleph 30 build by diyaudio newbie NiklasJ Pass Labs 8 7th February 2012 11:11 AM
Transformer for Aleph 30 Build Peter Daniel's Boards eeyore Pass Labs 4 18th May 2011 10:03 PM
Sharing my build progress of the F4 and Aleph 30 eeyore Pass Labs 2 9th May 2011 12:42 AM
WTB: Aleph-mini PCBs and transistor set for Aleph 30 needtubes Swap Meet 4 6th November 2005 06:29 PM
Copyright 1999-2017 diyAudio
