Old 16th February 2004, 01:47 AM   #1
kilowattski's Avatar
Default 200V 50A Fast Recovery POWER Rectifiers
Moderators, don't beat me up too much for this but I found this on ebay today. I know there will be alot of aleph-x's being built soon and hope this helps some of the builders.
STMicroelectronics BYV52-200 200V 50A High Efficiency Fast Recovery Rectifier Diodes in SOT-93 Package $1.00 ea.
http://cgi.ebay.com/ws/eBayISAPI.dll...&category=7287
Kilowattski
Old 17th February 2004, 12:00 PM   #2
Super_BQ's Avatar
Send a message via ICQ to Super_BQ Send a message via Yahoo to Super_BQ
Default Kind?
Are these the Schottky type of rectifiers? Only 3 pins config.
BQ
Yellow People for a Yellow World
Vote for Super_BQ, the Asian Alternative
Old 17th February 2004, 12:15 PM   #3
The previous auction has expired so the new one is at: http://cgi.ebay.com/ws/eBayISAPI.dll...tem=2596844068
The specifications for the diodes can be found at: http://www.st.com/stonline/books/pdf/docs/2963.pdf
I am not the seller. I spotted them and thought they would be of interest.
Kilowattski
Old 17th February 2004, 01:00 PM   #4
K-amps is offline K-amps  United States
K-amps's Avatar
Would these be good for amplifier PSU's oe would they generate gobs of RF?
I like the 500 amp peak burst value...
-K
Old 17th February 2004, 03:02 PM   #5
I believe one of their suggested applications is power supplies.
Kilowattski
Old 17th February 2004, 03:20 PM   #6
bigparsnip's Avatar
If you put some snubber caps accross the diodes this will help reduce any HF junk that is created by the switching.
You could have a look at this thread here (can I possibly plug this any more? ) if you are intrested in using these diodes for a power supply (They are very close to the BYW99W-200's that are now used in the PASS equipment I believe).
Old 17th February 2004, 04:13 PM   #7
K-amps's Avatar
Guy, SMPS are also power supplies and for those, I guess ultra fast recovery types are needed but for low tech Linear Amplifier PSU's (Toroid-Diode-Cap combo) I have read that the ultra fast types are a bad idea and that "Soft recovery" types are in order.
So if I understand you, these are good for Power amp applications as well?? And bigparsnip says that using snubbing caps will make them as good as any other .... correct?
Old 17th February 2004, 04:15 PM   #8
bigparsnip's Avatar
If you have a look in the link below you should find an answer to your questions of sorts (or at least on opinion from someone who is rather well respected round here.
high speed diode to-220 package for Aleph-x
Fast recovery diodes help / advice please ? AndrewGM Solid State 17 15th April 2009 09:39 PM
Fast Recovery rectifier diodes rtarbell Power Supplies 91 16th December 2008 06:38 PM
Fast soft-recovery controlled avalanche rectifiers? quantran Parts 6 5th May 2007 04:16 PM
Nice power supply with fast recovery diodes peranders Solid State 3 24th August 2004 03:04 PM
Power Supply Freds, Hexfreds, Ultrasofts, Ultrafasts and Fast Recovery boyelroy Solid State 116 1st June 2004 01:25 PM
Page generated in 0.09201 seconds (76.74% PHP - 23.26% MySQL) with 10 queries
