Old 15th February 2004, 02:27 AM   #1
hacknet is offline hacknet  Singapore
Default Zen Lite Buffer Stage
Hi i`ve just finnished by Zen Lite. it sound wonderful.
i`ve heard about implimenting a buffer stage to raise the low input impedence. i saw someone who used a BS250 mosfet as a buffer, problem being his suppy rail is 35volts while mine is 75volts.
does anyone has the schematics for a simple buffer stage i can impliment for my zen lite?
Old 15th February 2004, 05:36 AM   #2
Steve Eddy's Avatar
Default Re: Zen Lite Buffer Stage
Do you really need to increase the input impedance? You said it sounds wonderful so what's the "problem" that you're trying to solve?
se
Old 15th February 2004, 05:45 AM   #3
well, i`m running it off a tube preamp with a output capacitor. with the low impedence of the zen lite, the bass rolls off at 60hz.
i`m not suffering now as my below 100hz bass is augmented with a sub. i`m just looking for a way to raise it so i can sleep at night..
Old 15th February 2004, 05:53 AM   #4
Steve Eddy's Avatar
Ah...
How much excess gain do you have in your system? If you have about 12dB to spare, one simple (and passive) solution would be a 1:4 stepdown transformer.
Not only would your preamp see a higher load impedance (about 40k if you use something like the Jensen JT-10KB-D or DPC) but your Zen would see a much lower source impedance (rougly about 16 times lower).
So, if you've got some gain to spare, might as well put it to good use.
se
Old 15th February 2004, 07:13 AM   #5
well, my tubes are in a cathode follower fashion. and its about right now. i think i can get 12dB more gain.
from my memory, step-down transformers arn`t too cheap rite...?
Old 15th February 2004, 09:29 AM   #6
joensd is offline joensd  Germany
Hi hacknet,
have a look at this thread.
The last post shows a schematic with a buffer.
The only difference would be that you have much higher voltage rails. YouŽd have to scale R2 so that you get the appropriate voltage for your buffer.
Just think you have 75V drain at the regulator Q3 and your buffer draws 50mA for example youŽd need R2 to be 800Ohms to lose 40V. The resistor then would have to dissipate about 2W so you want to use a 3W resistor at least for that purpose.
Cheers
Jens
PS.: The buffer is described quite well in ZenV4 on the passdiy-site.
Old 15th February 2004, 10:57 AM   #7
thanks!
Old 15th February 2004, 12:20 PM   #8
just to make sure, is this how it is supposed to look like?
Old 15th February 2004, 05:24 PM   #9
Steve Eddy's Avatar
No, they aren't exactly cheap. The Jensen model I mentioned previously run about $70 each. Though you could probably find something less expensive from Sowter or Lundhal.
se
Old 16th February 2004, 09:27 AM   #10
nah, not my cup of tea. i`m not a fan of iron too.
well, i`ll try the buffer and see how it goes.
mosfet buffer for power stage hacknet Tubes / Valves 4 20th January 2007 05:39 PM
what do you think of my input buffer stage mazurek Parts 6 6th April 2006 03:03 PM
Fet buffer (?) for I/V stage ? Bernhard Digital Source 44 17th November 2004 09:38 AM
When is a buffer stage required? chipco3434 Solid State 5 16th August 2004 03:29 PM
x-bosoz as a buffer stage jjacks4x Pass Labs 1 5th December 2002 02:28 PM
Page generated in 0.10627 seconds (75.04% PHP - 24.96% MySQL) with 12 queries
