Old 15th February 2004, 02:16 AM   #1
Default Zen v.4 Bias Sensitivity Difficulty
I built a Penultimate Zen with the recommended component values for biasing Q1 (a 25K trimpot and 47.5K fixed resistor for R4 and R5). Starting with the trimpot fully CCW, the bias voltage at the drain of Q1 is low. As the trimpot is advanced, the bias voltage doesn’t change much. When R4 is almost full CW, the bias voltage suddenly changes from about 8V to 40V. The sensitivity is incredible – the bias voltage sweeps the entire range with only a few degrees of rotation on the trimpot. It’s impossible to set, because it is so sensitive. Both channels operate the same way.
My conclusion is R5 should be decreased, so that R4 is better matched. Is my thinking correct?
Old 15th February 2004, 03:08 AM   #2
BDP is offline BDP  United States
The pot adjustment with the supplied values works just great, no problems setting the bias. I would look some where else for your problem. If you could give more info, voltage reading, maybe someone could help you out.
BDP
Old 15th February 2004, 05:06 PM   #3
The one and only
Nelson Pass's Avatar
I would use an ohmmeter to check the actual values of the
resistor and trim pot out of circuit. Also, you could simply
subsitute in a resistor value, say 10K or 15K instead of the
trim pot and see what you get.
Old 26th February 2004, 11:43 AM   #4
pro is offline pro  Italy
pro's Avatar
Are you shure that the trimpot is connected in the right way?
I think only two legs mast be connected and one left floating.
difficulty with 1/2 clock to TDA 1541 tubee Digital Source 81 14th March 2008 02:25 PM
Martin Logan Quest Z 50Hz Difficulty Chris Daly Planars & Exotics 4 25th January 2008 03:00 AM
Sensitivity match in a 3-way system? all of equal sensitivity? or bass is 6db more? rhythmdiy Multi-Way 5 5th November 2007 11:33 AM
Difficulty Installing MathCAD with Win98SE kelticwizard Everything Else 22 6th August 2003 03:10 PM
Page generated in 0.06999 seconds (69.41% PHP - 30.59% MySQL) with 10 queries
