Official M2 schematic
Old 13th June 2018, 06:13 PM   #2741
1543 is offline 1543  Germany
1543's Avatar
Originally Posted by Mark Johnson View Post
The traditional position for a volume control would be "R2". Use a 100K pot to ground, input comes from R1, wiper goes to Q3 and Q4. Since it's DC coupled, if the input signal happens to have any DC offset, changing the volume control can produce a scratchy sound.
You probably don't want to drive the output stage from an impedance that varies with volume control setting. So you probably don't want to install the pot between the secondary and the output stage.
Probably not. The attenuator would have a fixed output impedance, did not draw that in layout, but I see it will not work w/o an additional buffer between attenuator and output stage.
Originally Posted by Russellc View Post
Odd, I note none of the soft low end or lack of detail.... I guess rooms, ancillaries, and speakers can change things up?
Rooms, ancillaries, and speakers should not be the cause otherwise the deficiencies would occur also with my main amplifier which has very high level of detail (Parallel-86 from Neurochrome) compared to the M2. I guess the M2 is not the best match for my speakers (German Physics Unlimited MK2, 88dB sensivity, 4 Ohm).
Will try if the F6 (next build) is a better match.
Old 13th June 2018, 08:18 PM   #2742
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
gimme a break !!
" Amplification required
Minimum 90W/4 ohms "
and you're driving it with M2's 50W ?
while Neurochrome is 120W/4R
with proper spks , M2 is waaaaay away from "soft low , soft high"
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 13th June 2018, 08:43 PM   #2743
PJN is offline PJN  United States
I think the F6 might be a better fit. I'm driving some not too efficient 3 ways with mine and it sounds great. My M2 also sounds great but is more picky who it plays with.
Old 13th June 2018, 08:48 PM   #2744
Zen Mod's Avatar
M2 is no nfb amp , it must be pickier
pair it with adequate Lautsprechers , that's Mana from Heaven
Old 13th June 2018, 08:51 PM   #2745
El Reino is offline El Reino  Finland
El Reino's Avatar
I have F6 and M2. My impression is M2 winner
Old 14th June 2018, 08:39 AM   #2746
1543's Avatar
Originally Posted by Zen Mod View Post
gimme a break !!
Perhaps you are right, however power amplifier wattages recommended by speaker manufactures are most based upon maximum dB the speaker can produce. In a test report of my speakers it was stated that the GP Unlimited can take a lot of power even from amplifier monsters but work well also with small amplifiers which also deliver dynamics and presssure.
Today I hooked up a MyRefc which can deliver ~68Watt at 4 Ohm to GP MK2 speakers. Bass response is better as with M2, though overall sound not as clean as the M2. Instrument/voice localization is nearly M2 but not as good as when PAR-86 is connected to the speakers.
Will test the M2 with Tannoy DC8BS speakers soon and start to finish the F6 build.
Old 14th June 2018, 08:51 AM   #2747
Zen Mod's Avatar
as I wrote - M2 is no-NFB amp and it's strength isn't primary in driving tougher loads
mate it with speakers based on proper 12" or 15" foundation , with no nasty behavior in impedance domain and it'll be in intended environment
for different ones , if FW stable is to choose from , choose amp with feedback , thus having lower output impedance and increased driving capability
Old 14th June 2018, 11:07 AM   #2748
Russellc is offline Russellc  United States
Same here. I found F6 closer to F5. It does indeed have a lot of high end detail. I turned my F6 into Aleph J and never looked back.
For harder to drive speakers, a complementary output BA3 with 30 volt rails does fine duty.
Russellc
Pass B-1 preamp, Pass BA3 preamp, Pass F-5 Amp, Pass F-6 Amp, Pass BA-3 Amp, Pass M-2 amp, Pass Aleph J amp, Pass Pearl 2 Phono pre Tekton Enzo, Altec A7, Econowave JBL 2235H & B&C CD
Old 14th June 2018, 04:56 PM   #2749
oreo382 is offline oreo382  Canada
Quick question,I am finally getting around to installing the buffer in my M2 boards.I don't have a 100k (R2) on hand but have some 47k resistors.Would those be ok to install and if no why not.Thanks in advance for any input.
Old 14th June 2018, 05:40 PM   #2750
Zen Mod's Avatar
it's OK , change it later
it's there to define Rin of amp
Official M2 schematicHide this!Advertise here!
First Watt M2 Kovax Pass Labs 154 13th February 2014 05:20 PM
JBL m2 ! Ahmad_tbp Multi-Way 0 7th February 2013 01:14 PM
First Watt M2 chrismercurio Pass Labs 16 18th March 2012 01:53 PM
swans m2 blue934 Multi-Way 0 22nd May 2008 05:56 AM
Audio Note M2 regulator schematic drobert Tubes / Valves 1 10th November 2007 03:09 AM
