Official M2 schematic
Old 12th June 2018, 08:12 PM   #2731
kbergsson is offline kbergsson  Iceland
Silasmellor I have the Diyaudio powersupply solution (8x 18000uf) in my F6 and unshielded 400VA trafo. Had some supply noise at first then remembered to do grounding excactly as 6L6s F6 build guide. My F6s are now totally silent on my 100+db Altecs.
Did you get your Kemets from surplus in Holland? I got mine there (tunasto) for a good price. Jonny Canuck, correkt 47000uf long life PEH200. Mouser has them as well but they are expensive. Mine are as said from surplus but according to datecodes all between 2 and 3 years old, seem to be unused.
I have some screens for the edcors on the way, if necessary, but they will be placed furthest from the trafos.
Old 12th June 2018, 09:23 PM   #2732
silasmellor is offline silasmellor  Denmark
Yes, I saw the link to that surplus store in another thread and snatched up some of those caps there as well. They are in mint condition, so a very nice find! How do you plan to connect them? I am thInking to use a dual 300va, 19v secondaries, and use 4x2 ohm (5w) between cap banks to bring ripple down further. Psud2 says that should give around 23v after the last caps.
I also use the grounding scheme from the guide. From psu board, via cl60 To chassis. Each amp board connected to +/-/gnd.. The noise is very faint with me ear next to the woofer, but I can see higher order harmonics in the fft which bother me (though i am not sure they are audible). I’m not sure if it is radiated noise from the transformer getting into the Jensen’s, but that’s currently my hypothesis.
Looking forward to more pictures, my build is still some way off, so I am curious how this works out (great I am sure).
Old 12th June 2018, 09:33 PM   #2733
coolnose is online now coolnose  Europe
coolnose's Avatar
Link?
Old 12th June 2018, 09:53 PM   #2734
It will be similar to your plans i.e. I have some 0R1 10w wirewounds as R in CRC, so 47000uf-0R1-47000uf and maybe 10uf large Wima as bypass per rail. The trafos I got are 2x 300VA dual 18V seconaries. I dont have any simulation sw. So If I like the sound is will be ok, If not Ill have to try something else
In the F6 I use shielded input cable with shield connected to gnd cable at input connector. I have used Tubes for a long time so if I dont hear noise I dont care
It will take some time to finish as I have not bought a chassis yet, and dont want to dissassemble my F6 to test the M2. I like the F6 to much
The store is Electrodump.nl i think.
Old 13th June 2018, 05:48 AM   #2735
coolnose's Avatar
Thanks!
Old 13th June 2018, 10:15 AM   #2736
As Im an assembler of kits and not a designer, I must give credit to ZM ( his nice 2M clone ) and older FW powersupply designs as inspiration for my simple CRC.
Old 13th June 2018, 02:27 PM   #2737
Skylar88 is offline Skylar88  South Africa
Correct link: elektrodump.nl
Old 13th June 2018, 03:34 PM   #2738
1543 is offline 1543  Germany
1543's Avatar
Default Get the most out of M2/F6
Had some time to listen to M2 amplifier I build few weeks ago. Soft low end, soft on top. I like the soft low end, but not the lack of details in music. When listening to music the lack of details is very obvious at some songs, however still something special, a bit like water color.
I am using allready transformers (jensen ground isolator) to avoid hum (cause by TV, SAT antenna) in my TV setup. To reduce sound impact of transformer I have placed the passive volume attenuator behind the transformer.
This reduces the THD&N at low freqencies for example by 14db (0db compared to -40db signal level according to jensen datasheets). Also the micro details in music are not lost and setup is more immune to inducted distortion by electric fields.
To get the most out of M2 and F6 I would like to place the volume attenautor also behind jensen / edcor transformers. For M2 this would be possible I guess. Could you help please if this would be feasible and what pot/relay volume attenuator impendance would fit best to match output impedance of transformer and the power transistors.
Any chance to put a dual volume control behind the jensen transformer in a F6? I do not know where to place.
Old 13th June 2018, 04:12 PM   #2739
Mark Johnson is offline Mark Johnson  United States
Mark Johnson's Avatar
The traditional position for a volume control would be "R2". Use a 100K pot to ground, input comes from R1, wiper goes to Q3 and Q4. Since it's DC coupled, if the input signal happens to have any DC offset, changing the volume control can produce a scratchy sound.
You probably don't want to drive the output stage from an impedance that varies with volume control setting. So you probably don't want to install the pot between the secondary and the output stage.
Old 13th June 2018, 04:14 PM   #2740
Russellc is offline Russellc  United States
Odd, I note none of the soft low end or lack of detail.... I guess rooms, ancillaries, and speakers can change things up?
Pass B-1 preamp, Pass BA3 preamp, Pass F-5 Amp, Pass F-6 Amp, Pass BA-3 Amp, Pass M-2 amp, Pass Aleph J amp, Pass Pearl 2 Phono pre Tekton Enzo, Altec A7, Econowave JBL 2235H & B&C CD
Official M2 schematicHide this!Advertise here!
First Watt M2 Kovax Pass Labs 154 13th February 2014 05:20 PM
JBL m2 ! Ahmad_tbp Multi-Way 0 7th February 2013 01:14 PM
First Watt M2 chrismercurio Pass Labs 16 18th March 2012 01:53 PM
swans m2 blue934 Multi-Way 0 22nd May 2008 05:56 AM
Audio Note M2 regulator schematic drobert Tubes / Valves 1 10th November 2007 03:09 AM
