Official M2 schematic
Old 15th May 2018, 07:43 AM   #2641
kbergsson is offline kbergsson  Iceland
kbergsson's Avatar
Or bend slightly, if its only a couple of mm.
Mpmarino, In the Norwegian Oil business they use the term "sledge mechanic" for those that dont posess the finer mechanical skills.
In Iceland the approach used to be different as the skills where there but availability of parts was poor so you fixed things with what you had In the late 70s i ordered a set of parts for a 66' Oldsmobile my father gave me. 3 years later I got only one part and it was the wrong termostat
Old 18th May 2018, 06:29 PM   #2642
kbergsson's Avatar
Got the Edcors today. They are the wrong ones ie 15k:600.
As the pins are of soft metal I tryed bending them so I can mount them rotated 180deg in the PCB. Seems ok. No I just need to wait for the PCBs
Old 18th May 2018, 07:43 PM   #2643
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
swell!
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 18th May 2018, 09:29 PM   #2644
zman01 is offline zman01  Bangladesh
Well, the parts are coming in... good luck with your build kbergsson! And keep us posted.
Old 19th May 2018, 09:26 AM   #2645
kbergsson's Avatar
Thanks zman01, I will
Old 20th May 2018, 02:21 AM   #2646
mpmarino is offline mpmarino  United States
mpmarino's Avatar
As the pins are of soft metal I tryed bending them so I can mount them rotated 180deg in the PCB. Seems ok. ........
Excellent! So you only needed a chisel
Don't feel bad. I ordered the wrong ones as well. Fortunately i think better while I'm asleep - woke up in a cold sweat and immediately sent an email asking for a change
Looking forward to hearing my M2 when it's done. Assuming it works at all
Crazy Yankee.
Old 20th May 2018, 08:14 AM   #2647
kbergsson's Avatar
Old 22nd May 2018, 01:34 AM   #2648
mpmarino's Avatar
Default I'm a screw up :)
Went to power the M2 up.
I totally messed it up. Never went back to check the board layout in relation to components. Used a footprint for the p-Mos with swapped source and drain AND used the wrong pin-out for the LM385 - DOH!
Serves me right for rushing. Did a swaperoony on the bottom of the board for the P -IRFPs and my LM385s now look like they are doing the twist
Now she biases up beautifully! What an elegant design - bias is so accurate and consistent.
Uses a 'universal' +/- 24V external PSU. It's still out in the shop, haven't heard it, nor done the finishing touches yet. Attached is a crappy pic (crappiness is intentional). Any similarities to a Big Boy Pass amp are purely intended
Crazy Yankee.
Old 22nd May 2018, 02:09 AM   #2649
mpmarino,
Good to know that you have your M2 clone powered up. You need to give it a listen! I think you'll be delighted.
One question - are those custom PCBs?
Old 22nd May 2018, 03:02 AM   #2650
mpmarino's Avatar
All in due time - actually, I'm a bit worried there are more mistakes
Yes, the PCBs are unique and home etched.
Crazy Yankee.
Official M2 schematicHide this!Advertise here!
First Watt M2 Kovax Pass Labs 154 13th February 2014 05:20 PM
JBL m2 ! Ahmad_tbp Multi-Way 0 7th February 2013 01:14 PM
First Watt M2 chrismercurio Pass Labs 16 18th March 2012 01:53 PM
swans m2 blue934 Multi-Way 0 22nd May 2008 05:56 AM
Audio Note M2 regulator schematic drobert Tubes / Valves 1 10th November 2007 03:09 AM
