Official M2 schematic
Old 28th January 2018, 12:58 PM   #2401
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
you have a problem with your regs , too wimpy for current nvolved
also , 10K in bias network is way too small , resulting in 5K or so input impedance of OS , further divided to buffer via xformer ....with square of voltage ratio
if xformer is having 4V/V , that is 5K/16 , taking too much burden to small toshibas
so , increase values in bias network
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 28th January 2018, 06:41 PM   #2402
blackdod is offline blackdod  Europe
Thanks ZenMod.
I use a similar PSU that F5ha so I don“t think that the psu is the problem. I measured around 165mA for rail. It“s not much
I use 3.3R on R16 and R22 and I measure 0.525Volt, a Bias around 160mA so this is ok.
What value would you recommend increasing the Bias network? Do you mean R6 and R24?
Old 28th January 2018, 06:48 PM   #2403
Zen Mod's Avatar
open new thread , give us necessary info and we will solve your problems
post reg schematic , and maybe even picture or two of amp itself
Old 29th January 2018, 09:30 PM   #2404
Thanks Zen Mod.
You are right, I changed r6 and r24 for 20K and.... tachannnnn
Now both rails works with +-15volt and a very stable offset but the Bias down from 160mVolt to 36mVolt. Maybe is a better idea change R16/22 ???
I“ll open a new thread tomorrow for share all information/pictures/schematics about this amp.
Old 9th February 2018, 05:59 PM   #2405
JimT is offline JimT  Canada
If anyone has a spice circuit for this I would appreciate a copy. I will need the model for the transformer and the 4N35.
Jim
Old 10th February 2018, 09:07 PM   #2406
flocchini is offline flocchini  United States
Default Toshiba 2SK1530 / 2SJ201
Completed my M2 changeover
Added Toshiba 2SK1530 / 2SJ201, reduced source resistors to .33 ohms and 0 ohms at R11. Using Tea Bag boards
Power by umbilical cord.
Nice involving sound with wide and deep soundstage. Great detail without fatigue
Highly recommended.
Best
Bob
Old 10th February 2018, 09:29 PM   #2407
Zen Mod's Avatar
again ugly sinks and motor run caps for signal
(what's Iq now?)
Old 10th February 2018, 10:19 PM   #2408
Iq is approx 1.7A
I had to use those Obbigato caps I had in a box
Maybe one day I will replace with Simlic II and your favorite bypass
Old 10th February 2018, 10:36 PM   #2409
Zen Mod's Avatar
OK
everything is forgiven , seeing those sinks
Old 11th February 2018, 08:50 AM   #2410
chede is offline chede  Germany
... fascinated by amps
chede's Avatar
Highly recommended.
Best
Bob
+1 for the same combination.
In my case built on JPS64 boards, with PSU in the same box, and I have a WIMA MKP10 for C2 and Elna Silmic II 3300 µF for C3 (bypassed by 1 µF MKC ERO1860).
My M2 runs with Iq of 1.81 A (Rails at +/- 24V).
Best regards,
Claas
Last edited by chede; 11th February 2018 at 08:53 AM. Reason: Added info on bypass caps for C3
Official M2 schematicHide this!Advertise here!
First Watt M2 Kovax Pass Labs 154 13th February 2014 05:20 PM
JBL m2 ! Ahmad_tbp Multi-Way 0 7th February 2013 01:14 PM
First Watt M2 chrismercurio Pass Labs 16 18th March 2012 01:53 PM
swans m2 blue934 Multi-Way 0 22nd May 2008 05:56 AM
Audio Note M2 regulator schematic drobert Tubes / Valves 1 10th November 2007 03:09 AM
