Transformer temperature
Old 3rd October 2015, 06:20 PM   #1
folkdeath95 is offline folkdeath95  France
folkdeath95's Avatar
Default Transformer temperature
I read many posts concerning heatsinks temperature (mine run at 45C, so no problems here), but what about transformer temperature.
I found that my Aleph J runs pretty hot, not only on the heatsinks but inside the case. When I opened it, I noticed that the transformer was very hot. I measured it at 70C. I didn't manage to measure the temperature of the mounting plate, but I can't leave my finger on it more than two seconds before it hurts.
Is it a normal "behaviour" for a transformer or do I have a problem?
PS: The trafo is a 300VA torodal unit from Amplimo.
Petite Onken/Altec 414-8B+Altec 808-8B/GPA aluminium diaphragm/Altec 811; Firstwatt Aleph J Clone; Denon DP5000F; Sphinx Myth9 MkII
Old 3rd October 2015, 06:39 PM   #2
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
what's VA consumption of amp and do you have enough air ventilation through case ?
picture or two will be good
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 3rd October 2015, 08:14 PM   #3
I don't know the consumption of the amp. It's an Aleph J, on Fistwatt's website, announced consumption is 200W.
Old 3rd October 2015, 08:24 PM   #4
nec3 is offline nec3  Turkey
70C is not high for a transformer.
Old 3rd October 2015, 11:32 PM   #5
Zen Mod's Avatar
is that HIFI2000 amp case ?
if yes , then you have enough holes in top/bottom plates
what Iq you set ?
Old 4th October 2015, 08:34 AM   #6
...........................PS: The trafo is a 300VA torodal unit from Amplimo.
Originally Posted by Zen Mod View Post
what's VA consumption of amp ...............
i...............what Iq you set ?
tell us more.
What is the AC current rating of your 300VA?
What PSU type have you fitted: Choke input or capacitor input?
What continuous DC current is/are your ClassA amplifier/s drawing?
70C for the surface temperature is very hot for a toroid transformer.
Have you any idea how much hotter the primary and the core is?
regards Andrew T.
Old 4th October 2015, 09:05 AM   #7
Yes, Zen Mod, it's a Hifi 2000 case.
Bias is set at 0.4mV, so I presume Iq is 0.85A (if I understand correctly what Iq is).
Andrew:
The transformer is an Amplimo 77014 with 2*115Vac primaries connected in series.
PSU is DIYaudio's Universal board, CRC filtering with 8*15000F and 8*0.47 ohms. Here is the bridge rectifier: Link.
Hope this helps.
Old 4th October 2015, 12:28 PM   #8
Zen Mod's Avatar
Iq would be twice that , per channel , having two pairs of outputs .
so , dissipation per channel is , assuming 22Vdc rails :
Pdiss=2 x 22Vdc x (2 x 0A85) = 74.8 VA
it means , xformer is tortured with steady 150VA
so , power taken - nothing to worry about
temp - little higher than I would allow it
however , just use it ....... bugger will either survive , or melt .
just take care to have proper mains fuse
Old 4th October 2015, 02:02 PM   #9
noelectrix is offline noelectrix  Europe
noelectrix's Avatar
may i ask a question concerning the "proper mains fuse", im just making new dual mono PSU for regular FW 22V rails amps (230 V).
My mains fuse at the Plug is 1,25A and its for both channels. When any trouble occurs its most often in ONE channel. So does it make sense to fuse the cables for the two transformers again with EACH the half of the mains fuse?
thanks,
stefan
Old 4th October 2015, 02:25 PM   #10
Zen Mod's Avatar
put one fuse per xformer , mounted either inside or on back panel
fuse value - xformer VA rating/mains voltage , then first standard value , slow type
however - when I'm making an amp , be it dual mono or stereo PSU , I'm usually putting just one fuse
when amp is properly done , I'm counting only on xformer melting ...... then even nail as fuse is effective .... enough
Transformer temperatureHide this!Advertise here!
Marantz CD-65DX transformer temperature? geoton4 Digital Source 0 5th September 2015 08:49 PM
300B Transformer temperature peter7 Tubes / Valves 7 27th September 2008 05:12 PM
Transformer temperature? Jeb-D. Tubes / Valves 11 7th August 2006 03:46 AM
