Old 12th February 2004, 01:09 AM   #1
www.audiohobby.com
Default How many parallel fets could BOSOZ drive?
I need to juice up my power follower and I'd like to run 3 or 4 MOSFETS in parallel. Wishful thinking? Also, how would an amateur determine this?
Old 12th February 2004, 05:56 AM   #2
Mad_K is offline Mad_K  Norway
Mad_K's Avatar
The BZLS doesn't care how many fet's you paralell. It's the Gate capacitance that gets porportionally higher when you put devices in paralell. This affects the HF response of the circuit (ie lower bandwidth). Do you have a schematic?
Mads K
Old 12th February 2004, 06:13 PM   #3
The one and only
Nelson Pass's Avatar
Default Re: How many parallel fets could BOSOZ drive?
No problem. If you really want to know, the best way is to hook
them up and observe the high frequency rolloff as you increase
the source impedance. In your case, I would expect them to
make to 100 KHz, depending on the devices.
Old 13th February 2004, 05:22 PM   #4
www.audiohobby.com
Thank you! I think I undersatnd now. I'll give it a try and let you know how it goes. I'll post a schematic too.
Old 15th February 2004, 03:41 PM   #5
www.audiohobby.com
Here's a schematic of my power follower with the BZLS driving it. You might recognize the follower as a heavy-duty "Zirclotron" (I just can't give up on this)
I haven't yet figured out exactly how to do the VGS multiplier for bias. This might make a good future tutorial for Mr. Pass. For now I'm sticking with the voltage divider bias.
Thanks again.
Mike
Old 15th February 2004, 06:02 PM   #6
Hi Mike,
First, I think you want R27-R28 connected to the left side of R31, and likewise for R29-R30 and R32.
Regarding a Vgs multiplier, I think the simplest approach with your circuit is to power it from V3 with the source tied to ground. I would set is up as a fixed Vgs doubler (using 2 10k resistors, say) with a pot in shunt with the doubler to tap off the bias voltage neeed. Then add two resistors in the 100k-1M range, one from the wiper of the pot to the right side of each coupling capacitor.
You could also add a balance pot, but I donj't think you'll need it if you use matched output devices. With this arrangement, you should also be able to drop the value of the 10uF coupling caps by 1-2 orders of magnitude. Good luck.
Old 17th February 2004, 10:46 PM   #7
www.audiohobby.com
Joe:
Thanks! You're a constant source of enlightenment and encouragement. I looked up what little info I could find on Vbe multipliers and came up with this contraption. Tell me what you think of this bias scheme:
As you suggested I could also power it from the input power supply. Do you think that would eliminate the need for a highly regulated supply for the output?
R16 is for fine tuning the balance. In this case (using MOSFETS in the multiplier) would you attach the IRF610's to the same heatsink as the outputs?
I thought it would be cool if I could figure out a little bridge circuit with a meter to adjust the balance. Still working on that.
Mike
Old 18th February 2004, 12:44 AM   #8
www.audiohobby.com
Well..I guess my nulling circuit idea is a little silly since all I have to do is measure the DC across the speaker terminals and adjust R16 for zero. Am I right on this?
Also, I had to make a couple of changes to the bias which I'll re-draw and post.
improving efficiency with parallel output fets Davey T Class D 6 3rd December 2008 04:37 PM
Parallel TPA6120 to drive speaker panson_hk Chip Amps 1 10th November 2008 02:44 AM
chipamp to drive heavy fets? h3 Chip Amps 0 14th December 2005 03:24 AM
2 x LM4780 in parallel to drive ESL panel Padel Chip Amps 6 3rd December 2004 04:44 AM
BosoZ - damaged FETS ? 2Bak Pass Labs 8 21st August 2002 12:18 PM
Page generated in 0.09892 seconds (77.38% PHP - 22.62% MySQL) with 11 queries
