Old 11th February 2004, 06:00 PM   #1
Bakmeel is offline Bakmeel  Netherlands
Bakmeel's Avatar
Talking Some serious Aleph Ono pr0n
My fellow DIY fanatics....
I am proud to present my very own and finally finished Aleph Ono!
I have been working on my project for more than 1.5 years now, where most of my time went into debugging the PCB's. Especially the first version was a complete disaster, and people who have read the "ono group buy" thread, might remember the catastrofy...
Nevertheless, I picked up work about 3 months ago, first finalising the second prototype, and then, after a few more tweaks the final version.
Most of the cost went into the capacitors. About €300,- all together. Of that budget, more than half went in the power supply which really is fenomenal. NO ripple whatsoever... . working deeper in de supply rails (further away from the rectifier), the caps have lower ESR, closer to the place where it is needed. With that in mind, I believe the PSU is really fast in response. The rest of the caps are really nice polypropylene and polystyrene caps.
Through Farnell, I was able to get a batch of fets, which all came off the same die (same batch numbers). I practically didn't need to match them... they were all the same
The case is MDF, cladded with copper foil on the inside for EMC shielding, and mahogany veneer on the outside.... 8 layers of lacquer were added.
The fronts were really special. I imprinted text on a piece of aluminium, then glued a piece of plexiglass (perspex) in front of it. The plexiglass has a groove milled in it, which is lit by the 7 (!) blue leds on top of the plexiglass. The leds themselves are invisible, there is just a nice blue glow over the aluminium and the plexiglass.
Then for the sound.... Unfortunately, my turntable is a real piece of crap. €5,- I once spent in a recycling store, and it sounds just like that. But nevertheless, listening through all distortion, it actually sounds really, really great...
Now for the promised pr0n
The front panels...
More Power Igor! More Power!
Old 11th February 2004, 06:02 PM   #2
Bakmeel's Avatar
The two, with glow on... (it can be regulated )
Old 11th February 2004, 06:03 PM   #3
Bakmeel's Avatar
.... And this happens when you turn the lights off...
Old 11th February 2004, 06:04 PM   #4
Bakmeel's Avatar
And these are the insides... The little board to the far left (with the silverish heatsink) is a dedicated "blue led regulated adjustable power supply"
Old 11th February 2004, 06:06 PM   #5
Bakmeel's Avatar
Close-up of the PSU
Old 11th February 2004, 06:08 PM   #6
Bakmeel's Avatar
... and the main boards.... note the extra bank of elko's in the psu rails at the bottom...
Old 11th February 2004, 06:11 PM   #7
Looks great Bouke!
Groeten,
Jarno.
Oemptempa petoempetapap
Old 11th February 2004, 07:41 PM   #8
Mad_K is offline Mad_K  Norway
Mad_K's Avatar
Very, very impressive work
Mads K
Old 11th February 2004, 07:54 PM   #9
Netlist is offline Netlist  Belgium
Netlist's Avatar
Default Re: Some serious Aleph Ono pr0n
Once I heard a Rolls had 17 layers.
Very nice amp. I particularly like the small black rectifier diodes surrounded by the red caps. What did you use as diodes?
Watch out!! The brown wire of the left trafo might come loose
/Hugo
Old 11th February 2004, 07:58 PM   #10
Bakmeel's Avatar
Default Re: Re: Some serious Aleph Ono pr0n
They are ordinary 1N4004 diodes, just like the schematics suggested. The red caps are wima mks 100nF / 100V
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 13 27th April 2012 02:13 AM
Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? tiefbassuebertr Pass Labs 17 9th January 2012 02:10 PM
Mini Aleph Board & Aleph 2 Parts List gpsmithii Pass Labs 3 16th January 2010 03:58 AM
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 0 6th August 2009 11:11 AM
PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers kristijan-k Swap Meet 64 12th September 2002 07:55 AM
Page generated in 0.13555 seconds (83.34% PHP - 16.66% MySQL) with 11 queries
