Parallel Aleph 3 or something else... - diyAudio
Old 23rd September 2015, 04:35 AM   #1
Default Parallel Aleph 3 or something else...
I'm loving my Aleph 3, but unfortunately I need it louder. My speakers are about 87db, and I'm using a B1 preamp. I really like the sound, it would just be nice to have a little extra.
So, I'm thinking about paralleling a second Aleph 3, or moving up to something larger. Will paralleling the amplifiers make much of a difference? Or should I be looking at an F5 or X?
Thank you in advance.
Old 23rd September 2015, 04:55 AM   #2
2 picoDumbs's Avatar
Depends on what the limiting factor is.
If it's current then yeah paralleling will help.
If it's voltage then no. You will need a balanced firstwatt amp (I'm assuming you DIY your amps)
Just do the test for yourself, since you already have the amp.
"If you leave this point unattached to some circuitry, an ideal constant current source will emit a small lightning bolt which will travel until it connects to something." Nelson Pass
Old 23rd September 2015, 04:57 AM   #3
What's your source output? 2Vrms?
Old 23rd September 2015, 05:11 AM   #4
I haven't measured it, but I would think it would be around there. Slightly higher from my phono stage.
Old 23rd September 2015, 05:14 AM   #5
Check it if you can.
I recently discovered one of my sources (pc) puts out less than 1Vrms.
Old 23rd September 2015, 11:01 AM   #6
wdecho is offline wdecho  United States
Definitely try a preamp with gain before deciding. My B1 preamp decreases the gain somewhat. I do not know the gain of the Aleph3 offhand but you may be pleasantly surprised. A BA3 preamp build is a good choice among others.
Old 23rd September 2015, 11:31 AM   #7
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
easy to test
cable with 3.5 headphone jack on one end and two RCA on other
connect either your boombox , laptop , smartphone to Aleph input , and try do you then have satisfactory SPL , taking in account somewhat lesser sound quality from chosen source
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 23rd September 2015, 01:35 PM   #8
Preamp with gain. I had a similar problem with F-5 and B-1. Built BA-3 preamp, problem solved, plus wonderful preamp.
Russellc
Pass B-1 preamp, Pass F-5 Amp, Pass F-6 Amp, Pass BA-3 Preamp, Pass BA-3 Amp, Pass M-2 amp, Pass Pearl 2 Phono
Old 23rd September 2015, 06:25 PM   #9
Danger Mouse's Avatar
A idea is to try biamping if your Speakers allow it.
Aleph 3 for highs and/or mids and a bigger amp for bass.
But try more gain at preamp first.
Old 23rd September 2015, 06:52 PM   #10
Thank you all for the great suggestions and information. I think I'm going to jump straight to a different preamp. That seems to be the consensus. After reading up on the BA-3, it sounds like a no brainier for me. Besides, I haven't made anything in a couple months so I'm due.
Parallel TDA2052 vs Parallel LM3886 for subwoofer goldyrathore Chip Amps 24 21st October 2013 05:50 PM
winISD calcs: parallel vs series-parallel sadams Multi-Way 1 20th February 2011 07:45 PM
What if aleph-p is run in parallel? PatPet Pass Labs 4 2nd August 2004 02:42 AM
Parallel amps & Parallel Voice coils? officeboy Multi-Way 7 26th May 2004 07:12 PM
Parallel Zen4 wth Aleph 5 MikeW Pass Labs 1 8th December 2002 06:59 PM
Copyright 1999-2017 diyAudio
