I am trying to increase my rails from 80 to about 100vdc for my amp so that under load they drop to only 75vdc or so. (and not the current 62 vdc they come down to under full load.)
While I can replace the outputs and drivers with hi-volt types, I do not want to play around with the input stages and leave them at 80vdc or so. Whats the easiest way to do it? I have considered the following: 1) Zener and resistor combo running off the main rails. 2) Connect 4-6 diodes in series to get the desired voltage drop from the main rails. 3) Dedicated power supply. 1 and 2 would have a smoothing cap at the end for some regulation. Any thoughts would be appreciated, |
#2 |
The one and only
Sounds like your transformer is kinda small to drop so much.
The front end could easily be driven by follower transistors whose base is driven by Zeners (in series for the voltage you want) in parallel with a small cap, forming reference which in turn is biased by a resistor to the supply. Standard stuff that works well. |
#3 |
Thanks Nelson .
Your note on the transformer.... well its an Adcom 555. I think it is a 700 VA unit with 30,000 uF per rail. At max load the rails drop to 62-3 v per rail or so. Funny thing is, the AC secondaries drop only 3 volts from 60vac to 57 vac. Does one volt drop on the AC side (pre rectification)mean more than 1.414vdc drop on the DCside or is it because of the RMS vale of the AC to DC conversion. Or lets say I used a 1.5kVA transformer instead keeping the same caps, what voltage drop do you reckon I should be able to get under 700 watt load? K. |
#4 |
The one and only
The calculation is complicated because a loaded transformer
is no longer putting out a pure sine wave, and you have to evaluate it based on peak voltages, which are what are really charging the caps. If it's a 555, then your loading is also a function of continuous high power, which is not characteristic of real music - I wouldn't worry about it. If you want, try decoupling the front end from the main supply using simple RC filters. |
#5 |
Thanks thats what I think I will do. Would you advise a zener diode for better regulation and yet keeping it simple in implementation?
thanks again!! |
| Voltage references for input and VAS stages | kl | Solid State | 0 | 10th March 2009 03:19 AM |
| Power amp input stages from National | Calvin | Solid State | 1 | 14th July 2008 06:18 PM |
| Cascoded LTP input stages | Mindaugas | Solid State | 20 | 13th April 2007 01:21 AM |
| Input stages - to decouple B+ or not? | andyjevans | Tubes / Valves | 1 | 9th March 2004 10:28 AM |
| Dual-differential input stages | Jon T. | Pass Labs | 14 | 2nd October 2001 08:53 PM |
| Page generated in 0.07361 seconds (77.71% PHP - 22.29% MySQL) with 10 queries |
