F5 - higher gain changing sonic signature - diyAudio
Home Forums Rules Articles diyAudio Store Gallery Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Old 24th August 2015, 09:00 PM   #1
Default F5 - higher gain changing sonic signature
Hi
I wanted some extra gain in my F5. Doubling feedback resistors for another 6dB.
So far so good, everything works fine.
However, now I'm getting my doubts if some life and upper details disappeared.
Will the sonic signature change with higher gain?
Other distortion pattern perhaps?
Any experience or theory is welcome!
deerhunt
Old 24th August 2015, 09:48 PM   #2
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
off course that different feedback amount will change THD spectra
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 24th August 2015, 10:13 PM   #3
The one and only
Nelson Pass's Avatar
As you raise the gain, there is less feedback, so things will change a bit,
but the F5 had plenty of feedback already, so no big loss.
It may easily be that you will prefer this after a while.
Old 25th August 2015, 03:00 AM   #4
EUVL is offline EUVL  Europe
MOSFET models from Bob Cordell.
Patrick
xen-audio.com
Old 25th August 2015, 03:20 AM   #5
Spectrum plots.
Left is G =6, right G=11.
Patrick
xen-audio.com
Old 25th August 2015, 04:15 AM   #6
2 picoDumbs's Avatar
I have a question.
A quiet room measures about 40dB.
If I listen to music with peaks never exceeding 100dB would it be fair to say that harmonics that sit below 60dB down on the FFT are completely inaudible (100-60 = 40dB Silence)
Old 25th August 2015, 04:48 AM   #7
Originally Posted by deerhunt View Post
Hi
Could be simply due to change in output impedance (damping factor).
Old 25th August 2015, 05:03 AM   #8
jcx is online now jcx  United States
and you can't really believe your ears unless you've amplitude matched the listening comparison to ~ 1% V, 0.1 dB SPL
Loudness Curves, articles from mixing engineers say small, too small to be clearly labeled by ear alone as loudness differences still give differing perceptual frequency balance
blinding protocol, ability to switch quickly and you can be more confident of such subjective statements before theorizing over the circuit causes
soundcards ( even motherboard chipsets), dividers, free sw can easily let you see clearly audible frequency response changes by measuring the loaded amp output V
Old 25th August 2015, 06:07 AM   #9
From memory the F5 amp has a frequency bandwith of around 1MHz. I doubt any subtle differences in frequency response around 1MHz will be audible.
Old 25th August 2015, 06:50 AM   #10
if output Z interacts with load Z, especially multiway loudspeaker, XO peaks and dips then you can have frequency response variation at audio regardless of amplifier bandwidth
Changing the gain on a FW F5 PMA! Pass Labs 1 6th June 2014 01:33 PM
Biasing the F5 higher, new trim pots? lorienblack Pass Labs 7 12th February 2014 06:55 AM
Effect of changing C but not L in higher order xovers madisonears Multi-Way 2 2nd August 2009 02:06 PM
For Sale Sonic Frontiers SFL-1 Signature Line Stage Preamp kilohertz Swap Meet 0 7th February 2009 06:58 PM
Changing Gain of Sonic Impact Gen 2 unit ttan98 Class D 4 26th November 2008 05:34 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
