I'm not a design engineer but obviously the major differences are that they are balanced and unbalanced designs but if one took the "L" ver 1 circuit and added Q-17 and associated components would there be any performance gains. I am assumming that Q-17 and parts are there in the "P" ver. 2 to allow cross coupling...but what other benefits are there? Or would there be any? Just looking at ways to improve the basic "L" itself.
Thanks in advance for any tips and answers! Mark |
#2 |
The half of Aleph P1.7 seems to be almost the same as the L circuit,accept that negatie CCS.
I'm no expert here ,but I think that applying this CCS to Aleph L might bring some benefits. Also if you want better sound than Aleph L build Aleph P. Even using it unbalanced (negative input grounded and negative output unused) it sounds better than L.Not a whole lot but quite a bit better.Just a couple of mosfets and resistors more ,and still no need for balanced volume control. Bartek |
#3 |
That is part of what I was wondering. Why don't I just build half of the P instead? For single ended use what benefit does the other half give me?
Mark |
#4 |
You could feed the preamp single ended and use balanced interconnects to the amps. If there is any advantage to balanced line, you would still benefit here.
#5 |
I think even when used unbalanced in/unbalanced out Aleph P will sound better than half of it.I guess other half brings some improvements,some distortion cancelation,makes it diffrent/better preamp.
Bartek |
| 2 questions on the aleph-p | jarthel | Pass Labs | 4 | 11th July 2007 08:24 PM |
| New Aleph 5, questions | gianc | Pass Labs | 6 | 23rd February 2006 12:30 AM |
| more aleph 2 questions | Mattyo5 | Pass Labs | 19 | 19th February 2005 11:51 AM |
| Aleph-4 Questions | mrfeedback | Pass Labs | 8 | 28th June 2003 03:57 AM |
| PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers | kristijan-k | Swap Meet | 64 | 12th September 2002 07:55 AM |
| Page generated in 0.07392 seconds (71.68% PHP - 28.32% MySQL) with 10 queries |
