Preamp input selector and common ground(s) - diyAudio
Old 6th August 2015, 08:47 PM   #1
max1979 is offline max1979  Italy
Default Preamp input selector and common ground(s)
I'm building my first preamp based on the well known LDR+DCB1 couple with unbalanced input.
I'm redesign the input selector and a simple (maybe silly) question came into my mind.
90% of the input selector (relays based) I've seen use a single DPDT relay to connect/disconnect one input, both the channels on the same relay. The grounds of the two channels (for all the inputs) are always connected to the common ground, this way we need one relay for each input we want to manage. Is it the best practice?
During the design of my input selector, I decided to use two DPDT relays for each input, one for left and the other for right channel. This way I can really disconnect unselected signal and related ground, closing the door for any unwanted noise. Is it useless? doubling the relays means better noise rejection or is just a waste of components?
Old 6th August 2015, 08:57 PM   #2
The one and only
Nelson Pass's Avatar
As a rule, I do not short the unused inputs to ground, and in that case I
don't see how it would matter - you would not be using all the pins on the
DPDT switch.
Old 6th August 2015, 09:23 PM   #3
DPDT switch.
So it's correct to use two relays for each input you want to manage, connecting/disconnecting both signal and ground of each channel?
Old 6th August 2015, 10:13 PM   #4
wayne is offline wayne  United States
In the hills
Normally one DPDT relay is used to switch both halves of a balanced signal with the grounds always connected. For single ended you could switch grounds but I don't see why you would want to.
wizards assistant
Old 8th August 2015, 08:37 AM   #5
Well, I have two doubts.
1) connecting all the grounds of the inputs means my cd reader, my turningtable and my other devices will be force to have a common ground.
2) the noise coming form unselected inputs and related connection cables will always be injected into my preamp
When we talk about input stage of an equipment I don't see any relevant difference between balanced and unbalanced. In both the cases we have to manage two wires bringing the signal and in case of unbalanced connection, the ground is also used as shield.
BUT considering that usually in case of unbalanced connection all the grounds are shortcutted... maybe I'm just making things more complex than needed.
Old 8th August 2015, 08:44 AM   #6
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
don't be silly .
and do whatever way you like .
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Arduino based Input Selector for preamp _atari_ Analog Line Level 5 30th June 2010 02:42 PM
common ground or not? Mordor Car Audio 5 7th October 2008 12:08 PM
A common ground between preamp and amp marthaman Solid State 4 3rd November 2007 09:00 PM
Preamp Input Selector & Buffers Devil_H@ck Chip Amps 9 2nd May 2004 10:29 AM
PIC input selector ( preamp ? ) breguetphile Digital Source 7 28th May 2003 10:45 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
