F6 Illustrated Build Guide
Old 9th October 2017, 12:00 AM   #951
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
well , you reprted that you have problem
try to be systematic , and use bulb tester
is diode bridge functional ?
is cap bank functional ( no shorts - check with buzzer on your DMM) ?
is everything oriented as prescribed ?
something is wrong ...... and as long pcbs are at your bench , only you can find where is the culprit
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 9th October 2017, 10:15 AM   #952
ilikeit is offline ilikeit
Which problem may be if after diode bridge i get only 17VDC (must be AC*1.414=25.45V) and on transformer secondary 18VAC. Also i try diode bridges from Vishay and remove thermistor, but voltage after diode bridge still remains 17VDC
Old 9th October 2017, 10:33 AM   #953
Zen Mod's Avatar
there will not be 1.41 without caps
voltage is pulsating in a way which DVM can't measure properly
check diodes with diode test , check caps for shorts
connect them together , power up via bulb tester
report here
Old 9th October 2017, 10:46 AM   #954
After powering off, light bulb can glow for 3 seconds...
Full size: https://i.imgur.com/CV0Mjug.jpg
Old 9th October 2017, 11:05 AM   #955
Zen Mod's Avatar
clarify
where you put bulb tester ?
it's usually connected in series with xformer mains
Old 9th October 2017, 11:19 PM   #956
I make an research, i make following decision - short in one or more caps.
Caps probably arrive damaged, because diode bridge functioning normally and everything is soldered correctly.
Also one of wire from diode bridge (600V 35A Vishay) moves when i turn on amplifer, that's because MUCH use of current - short.
Time to order new PSU PCB because i absolutely hate to desolder
Old 11th October 2017, 08:29 PM   #957
silasmellor is offline silasmellor  Denmark
Originally Posted by 2 picoDumbs View Post
From the results Euvl posted keratherm performed even better than mica and goop.
I haven't personally done that comparison (mica vs keratherm) but I wouldn't doubt it. Keratherm really is that good.
Originally Posted by Zen Mod View Post
Keratherm will deliver
Indeed, the package from DA store arrived today and switched them immediately - mosfet temperatures are now 25-30 degrees lower, so quite a difference. Temperature differential with heatsinks 2-5 degrees at the moment (depending on how much you trust my cheapo laser thermometer).
Interesting observation, after switching and letting the amp warm up, bias now reached just 0.38 V (it was biased to 0.5 V before). I guess that's all down to the mosfets operating at different temperatures (they were around 75-80 degrees before).
Edit: attribution
Old 11th October 2017, 08:39 PM   #958
2 picoDumbs is offline 2 picoDumbs  Australia
2 picoDumbs's Avatar
I've been sounding off like a broken record about keratherm, even tested them to prove the point.
Zen Mod says three words, and he gets all the credit.
You bastards. It's not like I'm getting paid here.
That's it the friendhip is over.
Hahaha
"If you leave this point unattached to some circuitry, an ideal constant current source will emit a small lightning bolt which will travel until it connects to something." Nelson Pass
Old 11th October 2017, 09:40 PM   #959
grimberg is offline grimberg  United States
grimberg's Avatar
Originally Posted by silasmellor View Post
...mosfet temperatures are now 25-30 degrees lower...
Is that just from switching insulator types? Without getting into the merit of which one is best, switching between silpad, keratherm and mica + goop never results in such a big difference. I would believe differences measured in single digits only. I know because I have tested several of them, including different types of thermal compounds when using mica.
Old 11th October 2017, 09:48 PM   #960
yeah. The previous ones were some that a guy from the local electronics shop sold me, so i have no idea what kind they were (there's a photo a few pages back but that doesnt help much), but they were clearly not doing their job very well...
F6 Illustrated Build GuideHide this!Advertise here!
F5Turbo Illustrated Build Guide 6L6 Pass Labs 416 18th June 2018 01:58 PM
BA-3 Amplifier illustrated build guide 6L6 Pass Labs 143 17th June 2018 06:31 PM
Aleph J illustrated build guide 6L6 Pass Labs 2662 13th June 2018 08:37 AM
diyAudio Power Supply Circuit Board v3 illustrated build guide 6L6 Power Supplies 680 10th June 2018 04:26 PM
ACA illustrated build guide 6L6 Pass Labs 137 15th May 2018 08:19 PM
