F6 Illustrated Build Guide
Old 16th April 2016, 02:09 PM   #501
PJN is offline PJN  United States
I opened My F6 up and replaced the burned R4 (18R) with a new one. Hooked up power and checked bias, was a bit high at ~ 0.6 V, then I noticed that R4 was very hot, lots of current going through so something else is bad. Looking at the schematic I'm taking a wild guess that Q1, or Q2 might have failed. All other components look good visually. I have a few spare IRFP240s in my spare parts so I'm going to replace both Q1 & Q2. Does anybody any other ideas ?
Paul
Old 16th April 2016, 02:20 PM   #502
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
that means you had high output offset
recheck input JFets , just in case
that's easy - just measure voltage at their source's meet point , while IRFP outputs are out of circuit
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 16th April 2016, 02:37 PM   #503
oreo382 is offline oreo382  Canada
If output offset is that high then that means high across one of the Jfets?
That Jfet possibly cooked too?
Old 16th April 2016, 02:45 PM   #504
Zen Mod's Avatar
well , I said - check JFets
Old 16th April 2016, 03:20 PM   #505
Hi Zen Mod,
Before I saw your response I had already changed out Q1 & Q2, still same problem, R4 getting very hot, just blipped on the power briefly, I quess the Jfets are cooked like you suggested. At this point I think I'll just repopulate the entire board in case something else has been compromised. Is there a chance that the input transformers have been damaged ?
Thanks,
Paul
Old 16th April 2016, 04:58 PM   #506
wdecho is offline wdecho  United States
Doubtful but anything is possible. Not hard to check once you get them off the board. Just check continuity where it should be. You will probably have to destroy the board to get them off unless you are extremely good or lucky or both.
Old 16th April 2016, 05:28 PM   #507
I'll just cross my fingers then and replace the rest, I can do that without destroying the board. Gotta go order some jfets.
Paul
Old 16th April 2016, 11:39 PM   #508
Bare is offline Bare  Canada
Small update on My F6 build.
Initially I wasn't happy with the sounds it produced... seemed as less than expected
Nothing wrong with my build or my speakers (checked everything to be sure)
Finally removed my George Wright penned tube/triode preamp..(which worked well in my preceeding setup).. fitted a 10 k Stepped atten cobble up as a rudimentary volume control ..a simple experiment.
INSTANT wonderful sounds.. a genuine Night And Day difference.
This one helluva good amp.
Sweet, Rich, exquisitely Detailed sounds.
Hearing is believing.
Matching seems as key and Good gear may not prove so good.. when the other bits are far better
Old 17th April 2016, 04:35 AM   #509
Russellc is online now Russellc  United States
Build yourself a BA3 front end as preamp, it compliments beautifully. Glad your amp is pleasing.
Russellc
Pass B-1 preamp, Pass BA3 preamp, Pass F-5 Amp, Pass F-6 Amp, Pass BA-3 Amp, Pass M-2 amp, Pass Aleph J amp, Pass Pearl 2 Phono pre Tekton Enzo, Altec A7, Econowave JBL 2235H & B&C CD
Old 17th April 2016, 12:52 PM   #510
Bones13 is offline Bones13  United States
Techie Wanabe
Bones13's Avatar
Some pre-amps have high output impedance that do not match well with these amps.
W4S STP-SE - DIY Aleph J - Zu Audio Druid V + Undertone
(Analog) VPI Scout Sig - K&K Audio Maxxed Phono (Digital) microRendu - Bryston BDA-3
F6 Illustrated Build GuideHide this!Advertise here!
BA-3 Amplifier illustrated build guide 6L6 Pass Labs 149 18th July 2018 07:45 PM
Aleph J illustrated build guide 6L6 Pass Labs 2676 18th July 2018 12:55 AM
F5Turbo Illustrated Build Guide 6L6 Pass Labs 450 12th July 2018 05:12 AM
ACA illustrated build guide 6L6 Pass Labs 142 10th July 2018 11:14 PM
diyAudio Power Supply Circuit Board v3 illustrated build guide 6L6 Power Supplies 688 4th July 2018 01:12 AM
