1) Remove Bulb Tester
2) Put in regular power cord
3) Bias to 0.25V across source resistors
4) Check dc offset
Now increase Vgs to 3 V and check everything.
Then increase Vgs to 3.5 and check everything
Turn each pot a little bit at a time while watching your multimeters
You should have one measuring Voltage across R1 or R2, and the other multimeter measuring dc offset
Let it warm up and check everything is still good
If everything is still good we will proceed to next stage.
4) Check dc offset
2 picoDumbs
I connected the WM directly to the power line, no Isolation trans. Humming still! Arggggg! I don't think it's a grounding issue...everything is lifted or floated. But I am seriously wondering if the input decoupling caps are not shielded enough. When i touch them the hum gets louder.
you mean CDO?
In anycase, I need some of that CDO now!
someone's OCD
you mean CDO?
- F6 Illustrated Build Guide
