F6 Illustrated Build Guide
Old 22nd May 2018, 12:11 PM   #1151
silasmellor is offline silasmellor  Denmark
Thanks for the reply Fabrice, may i ask what are the inductors you're using, and where did you source them?
Old 22nd May 2018, 01:39 PM   #1152
fabrice63 is offline fabrice63  France
fabrice63's Avatar
Inductors are Mundorf L125 , these are air core but I gave them an iron core to raise the Henry's ( better for ripple reduction ) , and it worked good , stock value is 3.3 mH , with the core is goes up to 10 mH approx , and they are far from saturation .
Old 22nd May 2018, 02:13 PM   #1153
Ok, i got the values right in PSUD2 now, had missed the "mili" prefix Looks like a nice PSU, but wowee, expensive compared to CRC...
Old 22nd May 2018, 02:20 PM   #1154
fabrice63's Avatar
it's a bit more expensive , but this amp really deserve that kind of PSU
an firts class power supply for an first class amp
Old 22nd May 2018, 05:07 PM   #1155
As much as i agree with you that this is a quality amp, i am unfortunately not flush enough to provide it with such a premium supply! However, i find that using 4x33mF (per rail) caps in the DIYAS PSU with 4x1.88R (0.47R) should give below 20mV ripple and keep the voltage above 22V. Practical question: The power dissipation across those four parallel resistors is approx 3.5-4W (assuming 3A draw). Is it still safe to use 3W resistors (since they share the load), or should i go to 5W or higher?
Old 22nd May 2018, 05:33 PM   #1156
fabrice63's Avatar
four 3 w resistor in parallel can handel 12 w , with 3 A load , each of them will "see" 0.75 A and "eat" about 1.7 v , so 3 w is well rated ,I think .
but 5 w wont harm , anyway
Old 22nd May 2018, 06:22 PM   #1157
Great, thanks Fabrice! In the future when i'm flush i will build a "proper" CLC psu for the amp
Old 18th June 2018, 11:58 AM   #1158
powerslave is offline powerslave  India
I tried my best to read this thread before asking questions however did not find it on F6's owner's manual too i.e. what is the power consumption when it's on idle (assuming one build's it as per guidelines and with same bias figures as illustrated on the 1st page) ? Secondly how long does one need to keep this amp on before playing music or if there is even any such thing with this amplifier ? I ask these because I wish to build something which I will use on a daily basis and should be able to use in weather conditions here in India without having to worry about AC or room temperature control etc.
Old 18th June 2018, 05:28 PM   #1159
Bare is offline Bare  Canada
Was concerned with all the Warm up talk too.
Welll... I'm lazy and just as often I turn it and enjoy.
Stone cold it still sounds better than ANY amp I've ever owned (been at this audio sillyness since '68)
Sometimes i will turn it on then come back a half hour later to listen.
Truth is the differences (yes there are some.. are Subtle tbh ) as in I find it far more enjoyable to warm it in use rather than waiting for it's best possible sounds
PS; the heatsinks don't seem to get more than barely warm.
Mine is a Poor room heater
Old 18th June 2018, 06:29 PM   #1160
If you dont bias too hot it should be fine (depending on chassis of course). I also rarely let mine warm up, and have not had the feeling anything is lost because of it. It only takes 20-30 mins or so before it will be warm anyways, so that time is quickly spent if the music is good, like Bare said
http://www.firstwatt.com/pdf/prod_f6_man.pdf
States 180W power draw.
F6 Illustrated Build GuideHide this!Advertise here!
BA-3 Amplifier illustrated build guide 6L6 Pass Labs 149 18th July 2018 07:45 PM
Aleph J illustrated build guide 6L6 Pass Labs 2676 18th July 2018 12:55 AM
F5Turbo Illustrated Build Guide 6L6 Pass Labs 450 12th July 2018 05:12 AM
ACA illustrated build guide 6L6 Pass Labs 142 10th July 2018 11:14 PM
diyAudio Power Supply Circuit Board v3 illustrated build guide 6L6 Power Supplies 688 4th July 2018 01:12 AM
