F6 Illustrated Build Guide
Old 7th October 2015, 10:22 PM   #101
audioexplorations is offline audioexplorations  Belgium
Will need to measure them. They were the b grade matched pair from the store.
5.1V zener is giving me max 70mV bias (cold), will pop the 6.2V in with the 3.3K resistors.
Old 7th October 2015, 10:31 PM   #102
2 picoDumbs is offline 2 picoDumbs  Australia
2 picoDumbs's Avatar
Best to know what Idss you have it could happen again.
I'd keep them under 9mA. Nelson recommends 8mA.
Zen Mod suggested putting a clip on heatsink which is worthwhile.
Either way you want to keep them under 55 degrees in my opinion.
How hot do they feel to the touch?
"If you leave this point unattached to some circuitry, an ideal constant current source will emit a small lightning bolt which will travel until it connects to something." Nelson Pass
Old 7th October 2015, 11:56 PM   #103
I'll have a feel tomorrow when I get the amp back up and running. The 6.2v zener with 3.3K resistor biases beautifully, very nice and stable. I almost destroyed the amp PCB when pulling out the 5.1v zener, the copper strip lifted off the surface of the PCB by about 1mm. Got lucky that it all stayed in tact. Not sure I'd be able to get away with pulling out the zener a 3rd time...
Old 8th October 2015, 02:31 AM   #104
abadsantos 7 is offline abadsantos 7  Philippines
abadsantos 7's Avatar
Since you have both experienced the 9.1V and 6.2V, How would you compare the bias stability between the two zener?
I have build my F6 using the 6.2V zener though Im using 5K. Bias
is quite stable too.
Cheers.
Old 8th October 2015, 03:38 AM   #105
Cheers.
5k is perfectly fine.
Old 8th October 2015, 07:12 AM   #106
noelectrix is offline noelectrix  Europe
noelectrix's Avatar
are the VISHAY IRFP 240 ok for this amp or do you recommend any other brand?
IR would be the other brand im able to buy.
I plan to buy a tiny batch of 25 pieces and try to get the best matched out of it.
Never did matching before so Ive no experience how much to buy.
stefan
Old 8th October 2015, 07:16 AM   #107
I'm using Vishay. I was under the impression that Vishay bought out IR, so these devices should be identical.
Old 8th October 2015, 07:24 AM   #108
stefan
25 is plenty although matching is not really that critical for F6.
Try and get them from the same manufacturing batch packaged in a tube, you will get better matching that way.
Old 8th October 2015, 07:34 AM   #109
noelectrix's Avatar
thats what i do and 25pcs is the smallest batch i can order. i just hope its not just 25 pieces, randomly packed out of a mixed huge bucket, but rather 25 nicely packed straight from production. Ill see
thanks for ur opinion,
st.
Old 8th October 2015, 07:50 AM   #110
st.
Looks like standard package in a tube is 25 from digikey.
They should be from the same batch (touch wood) as that is how the manufacturer packages them
F6 Illustrated Build GuideHide this!Advertise here!
BA-3 Amplifier illustrated build guide 6L6 Pass Labs 149 18th July 2018 07:45 PM
Aleph J illustrated build guide 6L6 Pass Labs 2676 18th July 2018 12:55 AM
F5Turbo Illustrated Build Guide 6L6 Pass Labs 450 12th July 2018 05:12 AM
ACA illustrated build guide 6L6 Pass Labs 142 10th July 2018 11:14 PM
diyAudio Power Supply Circuit Board v3 illustrated build guide 6L6 Power Supplies 688 4th July 2018 01:12 AM
