F6 Illustrated Build Guide
Old 5th December 2017, 03:13 PM   #991
Alistair72 is offline Alistair72  United Kingdom
Default Diagnostic Pics
Iíve attached some pics. Let me know if they arenít clear enough. I have more, I didnít want to swamp the thread with pics.
6L6, thanks in particular to you. Without your guide(s) this would just be a dream.
Al
File Type: jpg 8A641EF0-3107-4CEB-ABE6-979CD9F81EBE.jpg (428.4 KB, 226 views)
File Type: jpg 21C28800-5AA1-414A-BC88-CCC49B5DA9B2.jpg (482.0 KB, 213 views)
File Type: jpeg 4A57127D-45EA-4113-8C5F-B7714D80E6D4.jpeg (858.9 KB, 206 views)
File Type: jpeg 91280ACD-C6C3-4670-B827-561AD91C967E.jpeg (852.7 KB, 193 views)
Old 5th December 2017, 03:33 PM   #992
6L6 is offline 6L6  United States
6L6's Avatar
Al,
Have you tried to turn down the bias on channel B with the tester in place? It's unlikely you'll hurt anything with it (bulb) connected.
Re-attach the board to the sinks and give it a go. If the bias pot does react properly (I.E., you can get the bulb to dim) than attempt to bias to about 1/4 of the suggested ammount and adjust DC offset to zero. Then remove bulb and measure
Old 5th December 2017, 03:54 PM   #993
Originally Posted by 6L6 View Post
Al,
With tester in place, bias appears to read zero (Measuring across the legs of R2 - the green one just to the right of the cap in the first pic) and P2 does not seem to have any effect - no voltage or dimming of the limiter bulb.
There is a hot dust smell, but I canít locate any hot spot/components.
Old 5th December 2017, 03:56 PM   #994
6L6's Avatar
Hmmmmm. Ok, that's not right.
Look for poor solder joints, make sure your power connections are 100% proper, and doublecheck that you have no crumbs of metal in the Mosfet insulators.
Old 5th December 2017, 04:28 PM   #995
Smile Result!
Heated all the joints up again with a hot iron. Sorted. Must have had a duff joint despite them all looking right.
Both sides seem to be working. No LEDs functioning, but that might be down to buying the wrong thing. But both channels start up (individually and together) on the bulb tester with just a brief glow and then it goes off.
Right, now to swap leads and bias 🙂
I shall report back...
Thanks 6L6
Al
Old 5th December 2017, 04:47 PM   #996
6L6's Avatar
Wonderful news! Report back with results.
Oh, and turn the LED around on the PCBs , they are likely just in backwards
Old 5th December 2017, 05:34 PM   #997
And bugger! I think I have fried A.
So B is biased 0.505V and almost 0V offset (it flickers around 0 buy +/- 0.4 mV). The LED works.
I moved to A, in my enthusiasm I forgot to wind back the bias (from my previous attempt to bias it with the limiter in place). It started at about 1.5v and as I was turning it off I noticed a wisp of smoke from the middle, coming up the back of the PCB from Q2 direction. Q2 was hot. As was R1. Both too hot to touch, but cooled quickly.
I have redone all the joints (swapped the LED round) and whilst there centred the bias and offset pots. I have re-tested with with the limiter in place (all good) and now I am getting nothing across R2, zero volts with the power on.
Have I cooked it? I hope not.
Old 5th December 2017, 07:41 PM   #998
fabrice63 is offline fabrice63  France
fabrice63's Avatar
solder joint must be fully made on both side , not like post 991 .
I tell you this , because it made some issues on my setup
Old 7th December 2017, 03:21 PM   #999
Default H
Any tips folks? I neee to get ordering the bits if I am to beat the Xmas post.
Old 7th December 2017, 04:13 PM   #1000
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
most likely just new mosfets
check source reistors , just in case
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
F6 Illustrated Build GuideHide this!Advertise here!
F5Turbo Illustrated Build Guide 6L6 Pass Labs 416 18th June 2018 01:58 PM
BA-3 Amplifier illustrated build guide 6L6 Pass Labs 143 17th June 2018 06:31 PM
Aleph J illustrated build guide 6L6 Pass Labs 2662 13th June 2018 08:37 AM
diyAudio Power Supply Circuit Board v3 illustrated build guide 6L6 Power Supplies 680 10th June 2018 04:26 PM
ACA illustrated build guide 6L6 Pass Labs 137 15th May 2018 08:19 PM
