In honor of Nelson, and to make shorts less likely, we will be supplying mica and goop for mounting the active devices in the mini-kits
More small parts are being ordered, the final test amp is being built to confirm that all parts fit, as the project continues to creep along.
I tested with the same for mica and BeO without goop.
+ IRF9240 (mica) is cooler than IRF9240 (BeO)
+ The heatsink (BeO) is cooler than IRF9240 (mica)
Result: the mica is better than BeO a little bit and I think the reason is BeO is thickness and the mica is thinness, the difference is huge (about 30 to 40 times).
Without goop I think means you are mostly testing how well the surfaces meet up. The mica is smooth and flexes and the BeO doesn't. (that cracked piece is a bit scary, hope you kept away from inhaling any particles!).
Unless the transistor case is radiating signficiantly itself and the BeO insulators hardly conducting at all (not too likely), the heat sink temperatures should have been about the same if the power dissipated is the same and the heatsinks were the same. The relelvant measure, of course, is the device temperature.
Why not do a fair test WITH goop, as that's the only sane way they would be used?
Edit: found my old test of mica vs. alumina --
http://www.diyaudio.com/forums/pass-labs/37262-mica-goop-18.html#post4410496
http://www.diyaudio.com/forums/pass-labs/37262-mica-goop-22.html#post4417290
Without goop I think means you are mostly testing how well the surfaces meet up. http://www.diyaudio.com/forums/pass-labs/37262-mica-goop-22.html#post4417290
Exactly
not loosing my sleep about noise in this amp
Why am I still awake. Should be bloody sleeping.
Hahahahaha
Absolutely.This is a good result and surface is very important
The quality of the 2 mating surfaces is the limiting factor.
Papa Vfet P2 kit are with aluminium T bracket profiles
T bracket like this one :
http://www.diyaudio.com/forums/pass-labs/276711-sony-vfet-amplifier-part-2-a-102.html#post4628419
Greetings
Greetings
Can you measure the pin diameter of both the n- and p- IRFs? Mine differ greatly and don't fit the sockets I specified for my boards
- Sony VFET Amplifier Part 2
