Sony VFET Amplifier Part 2
Old 9th February 2018, 07:37 PM   #3491
luvdunhill is offline luvdunhill  United States
luvdunhill's Avatar
Originally Posted by dsdjoy View Post
Just opened the Gerbers. They are the single-pair output version.
I am interested in the two-pair output version as well.
Originally Posted by WalterW View Post
Ah, then that's causing the confusion. If I remember right, Nelson has posted the gerbers for the 4 output version also, some time ago. Haven't found it in this big thread yet.
Originally Posted by vvs07 View Post
Maybe we can ask Tea-bag to run another group buy of the boards.
I have some three output versions of an output stage that can be used in all the VFET designed posted.
I am trying out a creative way to mount the boards and devices, so it might not work for everyone, but I'm glad to share the boards that I have already made.
Old 10th February 2018, 09:53 AM   #3492
MASantos is offline MASantos  Portugal
If I understand correctly your board can be built with 2 pairs of Vfets only right?
What creative solutions are you looking into for mounting into the heatsinks?
Old 10th February 2018, 10:24 AM   #3493
massimo is offline massimo  Italy
3 pairs indeed and 2 mosfets used as regulators
Beware of the 4 capacitors too close to the heatsink. Elcaps hate high temperature.
Old 10th February 2018, 04:40 PM   #3494
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
(referring to the original vfet2 document)
any issues increasing C1 and C2 to 660uF (the caps across the reference that biases the mosfets)? I have extra holes on my board that are begging to be filled. need symmetry and all that.
Yes. You do not want to delay the time it takes to achieve bias voltage.
Old 11th February 2018, 12:48 AM   #3495
luvdunhill's Avatar
I am using board level pin sockets for all the TO-3 devices and avoiding a L-bracket which is hard to get precision cut in small quantities.
Here is a prototype at 1.5A per rail.
Old 11th February 2018, 12:55 AM   #3496
luvdunhill's Avatar
Thank you!
In the CSX2 there is 1000uF in a similar position C3 (not for the VFET bias voltage but for the MOSFET bias). Perhaps only the vFET bias cap is important to not make too big? With more vFETs, should this 220uF cap for the vFET bias be lowered still?
Old 11th February 2018, 04:55 PM   #3497
The one and only
It's simply a matter of seeing to it that the bias voltage comes up faster
than the regulated rails, otherwise you can see a lot of current through
the output stage.
Old 12th February 2018, 04:52 AM   #3498
Msr Mojo is offline Msr Mojo
I'd be interested in a pair.
Please PM me (yours is full).
Thanks.
M
Old 12th February 2018, 10:38 AM   #3499
dsdjoy is offline dsdjoy  Germany
I am also in interested in a pair of 3 output PCB. Thanks.
Old 12th February 2018, 11:06 AM   #3500
R-K Rønningstad is offline R-K Rønningstad  Norway
R-K Rønningstad's Avatar
Me too
Sony VFET Amplifier Part 2Hide this!Advertise here!
PCBPCBs for Nelson Pass‘ CSX1 SONY VFET amplifier permaneder Group Buys 428 27th May 2018 02:25 PM
Sony VFET Amps Nelson Pass Pass Labs 228 14th April 2014 11:04 PM
Sony Vfet housing Solid State 26 26th January 2014 03:38 AM
Sony TA-N7B VFET Help!! gpdavis2 Solid State 16 24th October 2009 01:20 PM
Sony VFET...tragic... EchoWars Solid State 21 11th November 2006 11:40 AM
