Sony VFET Amplifier Part 2
Old 11th August 2017, 03:24 PM   #3121
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
instead of VFets , solder 1K8 resistors
resistor between D and S of VFet
plain MF 600mW resistor will do
be sure that FB net is enclosed
power on, set both VFet bias voltages to max and same voltage (P1 and P2 , voltage say + and - 12V) at gates of VFets
now check all interesting nodes
power off ,desolder 1K8 resistors, mount VFets (check torque , check isolation to heatsink) , power on and set Iq and offset
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 11th August 2017, 03:30 PM   #3122
Gyuri is offline Gyuri  Hungary
Gyuri's Avatar
Zen said.
Those who would have deserved the life they are all dead already. "Oh, my dead dears!" - Captain Cat
Old 11th August 2017, 08:43 PM   #3123
dbis is offline dbis  United States
Thanks Zen Mod,
Sounds interesting. Bear with me, but if I'm understanding right it's a way to check that my circuit's ok without risking the Vfets, isn't it? I just have couple questions:
1. Right now I have P1 and P2 adjusted to the numbers written on the Vfets + 1V. When I remove the 1K8 resistors do I set P1 & P2 back to those voltages?
2. I know, silly question, but what's the "FB net"?
Old 11th August 2017, 09:00 PM   #3124
Zen Mod's Avatar
1.bias voltage higher than V+1 will just brake VFets even more (when you mount them in circuit) , minimizing any possible damage ; setting these two voltages to same value will result in , say, proper range of final output offset ....... remember that's just a test of entire circuit , but without risking precious ones
2. Feedback net
Old 11th August 2017, 09:33 PM   #3125
Thanks Zen Mod.
Old 12th August 2017, 01:12 AM   #3126
alvinlim is offline alvinlim  Malaysia
Originally Posted by dbis View Post
Hi Gyuri, Yeah seemed a little funky to me so I think I may have measured it wrong. All my resistor and voltage checks before applying power to the front end were ok. I always use a dim bulb to power on for the first time and that was fine too. Thanks.
I did not use the "dim bulb power on" with the VFET installed due to this statement in the documentation....
"If you have a Variac for this, you will want to use it, but keep in mind that it is only useful for providing a relatively low inrush current to the power supply capacitance – you cannot raise the AC line voltage too slowly or you risk having the VFETs draw too much current while the bias voltages are being established.
I suggest that you raise the AC line to voltage you have a Variac for this, you will want to use it, but keep in mind that it is only useful for providing a relatively low inrush current to the power supply capacitance – you cannot raise the AC line voltage too slowly or you risk having the VFETs draw too much current while the bias voltages are being established.
I suggest that you raise the AC line to voltage over a period of less than 5s"
I think the bulb will limit the AC line voltage - more technical members can comment on this
Old 12th August 2017, 06:30 AM   #3127
Gyuri's Avatar
First time, when I powered up amp with VFETs, I used a variac and a lightbulb series with it. I worried about it: "you cannot raise the AC line voltage too slowly".
What can be too slow here?
So I watched voltage drop on R32. At low voltages, it raised quickly because VFETs are normally on. So it was better to turned it off.
Then, I've got a big breath, and switched it on with light bulb at about 180VAC.
Worked flawlessly.
Later I have found with the variac's involvement, that below somewhere half of the PSU voltages, current raises again, as VFETs gets closed.
Old 12th August 2017, 06:17 PM   #3128
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
The main point is - don't dawdle with the Variac, or if you do, then watch
the current draw carefully.
Old 20th August 2017, 03:19 AM   #3129
Joca is offline Joca  Portugal
Is a 9ma idss a no go? I can only find this in europe. What sources do you have in europe?
Old 20th August 2017, 06:18 AM   #3130
Gyuri's Avatar
Do you asks about 2SK170/2SJ74s?
I think 9mA Idss will be fine.
But be careful, is it original?
Sony VFET Amplifier Part 2Hide this!Advertise here!
PCBPCBs for Nelson Pass‘ CSX1 SONY VFET amplifier permaneder Group Buys 428 27th May 2018 02:25 PM
Sony VFET Amps Nelson Pass Pass Labs 228 14th April 2014 11:04 PM
Sony Vfet housing Solid State 26 26th January 2014 03:38 AM
Sony TA-N7B VFET Help!! gpdavis2 Solid State 16 24th October 2009 01:20 PM
Sony VFET...tragic... EchoWars Solid State 21 11th November 2006 11:40 AM
