Heatsink for F2J?
Heatsink for F2J?
Old 19th June 2015, 02:05 AM   #1
drjbf1 is offline drjbf1  New Zealand
drjbf1's Avatar
Default Heatsink for F2J?
I scrounged this from a 5 x 75w class A/B amp. It's 107mm high and 380mm long. Do you think it will dissipate enough heat for one channel of an F2J, which I think is 24v x 2.5A = 60w?
Why finish an audio project when you can start a new one?
Old 19th June 2015, 08:33 AM   #2
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Heatsink for F2J?
questionable .......
in case like that , I'm always making a test
variac , big xformer and stack of 50W dale goldies
or xformer and two mosfet CCS-es , each one set to half of desired dissipation
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 19th June 2015, 02:49 PM   #3
6L6 is offline 6L6  United States
6L6's Avatar
Heatsink for F2J?
If you are wiling to add a fan if it's not enough, then proceed.
But best would be testing like ZM suggests.
Old 19th June 2015, 10:18 PM   #4
drjbf1's Avatar
Thanks for the comments. I am not a fan of fans, so will run some tests, or buy some heatsinks.
cheers
Old 20th June 2015, 07:21 AM   #5
drjbf1's Avatar
I thought I would report back as I have never tested heat sinks before, and it might be of interest to others.
I had bits to do a quick test as per the photo. 21v with 2 x 15R to ground, about 1.4A at 30 watts each, 60w in total, the F2J dissipation. Not sure whether the meter temp probe or the blimey test are the more accurate. After 1.5 hrs of cooking the resistors are at a constant 36C, the middle top of the sink back plate 33C and a middle fin 27C. Ambient is 18C. I can hold my hands on the sink fins indefinitely, and can keep my fingers on the resistor cases easily for 10 secs and more.
Good to go, you think?
BTW the case the sink is sitting on is reserved for the Sony Vfet Part 2. It used to house the Pass A20 from the 70's until I blew up a channel some years ago.
Old 20th June 2015, 07:31 AM   #6
dady is offline dady  Balearic Islands
dady's Avatar
Send a message via MSN to dady Heatsink for F2J?
Hi, I think that is enough for one channel. Maybe using a fan in summertime, or in Rhapsody in Blue....
Esteban Bikić
Old 20th June 2015, 10:48 AM   #7
Zen Mod's Avatar
Heatsink for F2J?
Originally Posted by drjbf1 View Post
I thought I would report back.....
perfect
Old 20th June 2015, 09:23 PM   #8
drjbf1's Avatar
Thanks all.
Heatsink for F2J?Hide this!Advertise here!
F2J parts. oon_the_kid Pass Labs 37 14th September 2013 03:45 AM
F2J Input impedance drjbf1 Pass Labs 7 11th June 2013 05:01 PM
F2J technical question oon_the_kid Pass Labs 11 29th February 2012 11:58 AM
F2J Speakers match mc297 Pass Labs 6 27th January 2012 05:29 AM
F2J schematic needed neazoi Solid State 1 6th November 2011 04:35 PM
