Gyrator loaded Son of ZV9/F3
Old 10th April 2018, 10:48 PM   #201
juma is offline juma  Germany
juma's Avatar
Ok.
What's the load/speakers you intend to drive with it ?
Please don't use private messages for question related to audio projects. It defeats the purpose of the forum.
Old 11th April 2018, 07:54 AM   #202
marconi118 is offline marconi118  Germany
quite simple load
8ohm 15" woofer jbl 2226
16ohm compression driver jbl 2446
crossover at 800Hz
Old 11th April 2018, 11:17 AM   #203
juma's Avatar
500 mA will be fine.
Old 11th April 2018, 12:59 PM   #204
I will try that
thank for all
Old 18th April 2018, 08:52 AM   #205
can I use a SSM3K339R instead of the BS170? it has higher Yfs
Old 18th April 2018, 09:47 AM   #206
juma's Avatar
It should work but the curves/characteristics are different and the circuit has to be adjusted for it.
Higher Yfs brings nothing good here by itself.
Anyway, you are free to experiment and see/hear what you get...
Old 8th July 2018, 01:06 AM   #207
propitious is offline propitious  United States
juma: For the amp you put in post #164 (thank you for that) can you think of any reason to not use a cap multiplier PS like you posted for Cubie3, except it will be single rail only?
Old 8th July 2018, 09:31 AM   #208
juma's Avatar
No reason at all.
Only thing you lose is 4V of power supply voltage.
And don't forget to use R14 ( it can be even lower, down to 100R, depending on how leaky the coupling cap is).
Gyrator loaded Son of ZV9/F3Hide this!Advertise here!
L Loaded ZV9 Help??? flg Pass Labs 76 23rd December 2016 10:28 AM
cascoded gyrator loaded 6H9C to low idle. kees52 Tubes / Valves 11 29th December 2011 04:24 PM
F3 vs. ZV9 - the differences... HVfanatic Pass Labs 8 3rd June 2011 08:03 PM
Gyrator Loaded 12b4A: The Latest Version. SGregory Tubes / Valves 40 3rd January 2011 02:26 AM
First Watt F3 & ZV9 breguetphile Pass Labs 3 10th July 2006 10:53 PM
