Gyrator loaded Son of ZV9/F3
Old 18th June 2015, 09:48 PM   #11
bogdan_borko is offline bogdan_borko  Serbia
bogdan_borko's Avatar
Originally Posted by juma View Post
When I saw ZV9 for the first time it looked to me like a beautiful preamp topology made to an power amp thanks to existence of LU1014.
Few months ago I started to entertain this single ended preamp idea again and not only that the sound was exceptional (I like it so much that I removed BAF 2013 preamp from the case to move this one in although I thought that I'll keep the BAF2013 for a very long time), it showed other great qualities too: great drive/swing capability (Zout less than 50R and ability to drive power buffers like F4), great versatility in terms of gain and power supply used, low and steady consumption (10-12mA per channel), it's stable into reactive loads and the freq./phase response is linear up to 100kHz.
The story about this preamp actually started here but I think it deserves a dedicated thread. The main change from the original ZV9 is that I use gyrator instead of aleph CCS - it sounds better to me but it's easy to test both.
As a power supply I use 32V SMPS taken from dead HP inkjet printer, followed by a capacitance multiplier. The PCB is 74 x 25mm, copper side view. R9 is mounted on the output terminal and C3 (WIMA-MKP10) is beside the PCB due to its size. C2 is 2-5pF, made from two twisted isolated wires cut to length for best square wave response (I did this just because I don't have small value caps in my parts repository at the moment). As shown, the gain is 13dB (4.5V/V) but can be set as ratio of R1/R3 in a wide range (I tested 6-26dB). The clean swing at the output with 30V rail voltage is 24V peak-to peak (8.5V_RMS) into 10k load.
EDIT:
One thing I forgot to mention - due to RC constants present in the preamp and cap. multiplier, 10-15 seconds are needed for capacitors to charge and the sound starts to come out. You might call it: very slow start
Juma, nice and simple as always! Couple questions:
1. Whay is R6 referenced to the output?
2. Referencing C8 to the source of jfet (not ground) always sounded better to me, have you tried it?
Cheers, Borko.
Svakog dana u svakom pogledu sve manje nazadujem.
Old 19th June 2015, 07:20 AM   #12
juma is offline juma  Germany
juma's Avatar
Hi Borko,
That's the trick with "modulated cascode" as we now it from ZV9/F3 - practically it's the same idea that is more often used in source follower circuits where the botom end of cascode is modulated from the JFET's source which is the output node. It audibly linearises the operation - I noticed that with it this circuit can be used without the local feedback and it still sounds very good (although the gain is higher) which is not exactly the case with standard cascode.
Connecting the C8 to GND leaves some small "room" (in terms of voltage) for JFET to "breathe" (the Vds is not strictly fixed) and that solution sounds better to me. So, as always, it's matter of personal taste, although in this case the swing on the source of the JFET is very small - it swings only the amount of current that's drawn by the load times 4R7...
Best regards !
Old 23rd June 2015, 05:42 PM   #13
Dennis Hui is offline Dennis Hui  Canada
Hi Juma,
I'm wondering how high impedance do you think one can use for the input pot?
Thanks,
Dennis
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old 23rd June 2015, 06:05 PM   #14
juma's Avatar
Hi Dennis,
10k is an optimal value. If you happen to have an extra impotent source component that can not drive a 10k pot, use 25k pot, but in that case the R3 should be changed to 10k and R1 to 47k. If 25k is still too low for the puny source component, add a buffer between it and the pot.
Old 23rd June 2015, 07:16 PM   #15
Thanks Yuma. It's probably best I get a new pot.
Dennis
- NP 2002
Old 8th July 2015, 01:37 PM   #16
juma's Avatar
A fellow member asked me if this preamp can be made with simple BJTs only so I gave it a try and it works lovely.
He is OK with max. 6V_RMS at the output so the rail voltage is down to 24V.
Since the use of a BJT at the input and single rail PSU imply the use of an input cap I introduced local Schade feedback (R10, R3) to control the gain (about 13dB). Z_out is a bit higher (150-200 R) , Z_in too (47k), some elements' values are changed, but it still sounds very good...
Old 8th July 2015, 02:07 PM   #17
I ordered some BF862; hope I can actually see them.
- NP 2002
Old 9th July 2015, 07:04 AM   #18
juma's Avatar
Tiny little bastards, aren't they ?
Old 10th July 2015, 03:39 AM   #19
Got them today. Dang, they're small...
- NP 2002
Old 11th July 2015, 01:48 AM   #20
kp93300 is offline kp93300  Malaysia
JUma,
Is this the BF 862 used in the schematic?
It has two numbers ..
NXP BF862,215 RF FET, N CHANNEL, 20V, 25MA, 3-SOT-23
BF862,215 - NXP - RF FET, N CHANNEL, 20V, 25MA, 3-SOT-23 | element14 Malaysia
thanks
kp93300
Gyrator loaded Son of ZV9/F3Hide this!Advertise here!
L Loaded ZV9 Help??? flg Pass Labs 76 23rd December 2016 10:28 AM
cascoded gyrator loaded 6H9C to low idle. kees52 Tubes / Valves 11 29th December 2011 04:24 PM
F3 vs. ZV9 - the differences... HVfanatic Pass Labs 8 3rd June 2011 08:03 PM
Gyrator Loaded 12b4A: The Latest Version. SGregory Tubes / Valves 40 3rd January 2011 02:26 AM
First Watt F3 & ZV9 breguetphile Pass Labs 3 10th July 2006 10:53 PM
