Hi All,
I had to set my BOSOZ project aside for several months and am now about to finish it. I am wondering if there is any way that I could use the relays in an NAD 1600 (single ended) preamp for balanced source switching in my BOSOZ? I have a 4 pole switch that I was going to use and a pair of ALPS 10K POTS, but I'd rather turn the 4 pole switch into a stepped attenuator and use the relays for channel switching if I could. Thanks, Greg |
#2 |
Greg,
it´s no problem to use se relais for balanced switching. Just parallel two of them. One can handle the plus and one the minus signal. william
een ooievaar is geen konijn want zijn oren zijn te klein! |
#3 |
I looked at relays for use in my BOSOZ. No matter what you do you are going to need to switch 4 signals per input for the balanced connections. So you are forced to use either pairs of dual relays or a very expensive quad relay (which I chose, perhaps stupidly). So I don't know what's in your NAD 1600, but you will maybe need to double them up if they are only dual pole.
Also, don't be afraid to install some new ones, high quality NAIS D2 series relays (2 pole) or similar low signal relays can be had on the cheap, around $2.00 each. Here is my circuit. http://www.diyaudio.com/forums/showt...682#post296682 |
| Preamp source selection using relays question. | sjalloq | Solid State | 5 | 31st July 2009 03:01 PM |
| Relays for Source Selector | SRMcGee | Everything Else | 1 | 9th November 2008 11:02 PM |
| High Current relays for speaker switching? | Zero Cool | Everything Else | 13 | 16th December 2006 12:52 AM |
| Relays for switching i2s or other 3-wire audio bus? | mbcouple | Digital Source | 19 | 23rd July 2005 09:58 AM |
| BOSOZ I/O and Switching Recommendations | vdi_nenna | Pass Labs | 12 | 10th May 2005 02:29 PM |
| Page generated in 0.07072 seconds (73.08% PHP - 26.92% MySQL) with 10 queries |
