Aleph 3 diy problem with one channel - diyAudio
Old 23rd May 2015, 07:13 AM   #1
Default Aleph 3 diy problem with one channel
I've been messing around with this long enough and I'm ready to seek help... That being said: I've built a Aleph 3 and I'm having a terrible time figuring out a problem I'm having with one channel. The unit starts up and I dialed in bias and offset and just when I plugged in my iPhone to check it, it went pop. My phone that is. The 3.5mm jack blew up on my phone.
I checked and found I had offset voltage on the input from one channel reaching .6volts and the other side was at 0. I blew a capacitor on the side with the voltage. After replacing it I checked input offset and found it had returned to 0 on both sides. I put the project down a couple days and thought it over.
Today I returned to it and I measured voltage at the input and found one channel to have 0, like it should, and the other to have -27volts! The one with the voltage issue is the one that has performed correctly all this time without any failure. I measured across the voltage rails and I have 55 volts, but 53 from the negative and 2 from the positive to chassis ground. I also have -27volts on the "ground" coming off my supply capacitor bank.
All my voltage reading are off on this channel and I have no idea where to start. I disconnected the power supply from the amplifier board and it performed as it should, + and -27 volts. As far as I can tell, the negative voltage is feeding back through the entire system through the ground and I'm not sure why or why the negative voltage is so high. One last piece of evidence is I found a blown diode on this channel as well, but after replacing it nothing changed.
Any ideas on where to start or what to check would be extremely helpful. Thank you.
Old 23rd May 2015, 09:06 AM   #2
hates ground loops
Rodeodave's Avatar
For starters, as always, post pics. Ideally post a schematic of the actual build showing wiring and with voltage measurements annotated.
Check all solder joints for bridges.
Gravity - Making the G since 13.7 billion B.C.
Old 23rd May 2015, 06:00 PM   #3
Default schematic and pictures
Here are some pictures as well as a schematic with measurements. Only difference as far as I can tell in the schematic is that I'm using 2 variable resistors to adjust bias and offset. All the measurements are done checking voltage using chassis ground.
Old 23rd May 2015, 06:09 PM   #4
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
using solid core fatties soldered to pcb is recipe for disaster
remove them , remove pcbs from heatsink and inspect is there any damage to traces
also - try power supply with some load
say that 100W bulb across one rail will be as 25W load
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 30th May 2015, 02:28 AM   #5
I ran a couple 8ohm 25watt resistors across the rails and measured. They stated to smoke after about 30 seconds, but I got the measurements before. About 27volts on both sides. Will this suffice for testing the power supply under load? Clearly having no idea that solid core is bad for this situation, could you please explain why? I have the pcb off the heat sink and cannot see any damage. The diodes are good and the resistors measure good and are not burnt. Really all I can think to do is remove the transistors and check them as well as the board traces. I could also remove the capacitors and measure/replace them too.
I just really have no idea what would cause this to fail and then cause the voltage irregularities I'm measuring. My only guess would be the mofsets on the positive side? Is there a way to test them in the circuit? Maybe similar to matching then?
Old 30th May 2015, 07:26 AM   #6
-27volts on the "ground" coming off my supply capacitor bank. --> that mean isolate Mosfet to heatsink problem...i think.
Old 31st May 2015, 12:46 AM   #7
Yep! Thank you.
Old 2nd June 2015, 10:22 PM   #8
Andersonix's Avatar
Why is that, ZM?
Old 2nd June 2015, 10:54 PM   #9
6L6 is offline 6L6  United States
6L6's Avatar
Probably thermal expansion as they get hot, and break PCB traces.
Old 2nd June 2015, 11:14 PM   #10
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
1/100th of an inch, really ?
Hasi bo best
WTB: DIY Aleph J complete or First Watt Aleph J nicksgem10s Swap Meet 2 3rd January 2014 07:24 AM
Any Aleph / X Aleph DIY members in Western Australia? macka Pass Labs 2 6th September 2006 12:35 AM
Aleph DIY x100 and Wilson Audio-low impedance problem. elviukai Pass Labs 11 9th March 2006 06:36 PM
Problem with one Aleph 2 channel Lucas_G Pass Labs 9 25th September 2003 01:04 AM
Aleph three channel rickie Pass Labs 1 11th July 2002 07:11 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright ©1999-2015 diyAudio
