My own X-Zen monoblocs are running at 2.7A each and uses Aleph current sources in the upper zone of the differential pair, and a constant current source at the tail. The CCS works at 5.2volts and at the output points there are 21.7 volts . The supply is fixed at 38V.
Signal and Aleph CS Fets dissipate around 21.5W and the sinks temperature is actually low. DC offset between the speakers terminals is 2 or 3 mV. Design reflects the JH6you one in the x-soz thread but I introduced a CCS instead of resistors at the tail , for a better X effect and low dissipation. The pics show my own realization , based in a wood box + separated heat sinks for each fet so I've been able to avoid insulators between fets and sinks. There is a fully simmetrical lay-out in terms of pcb and cables lenght, and I have selected the devices for a match of 15mv max vgs.I do not have very good parts though , especially power resistors , but I am happy with they anyway. Schematic reflects the circuit as I build It . The babies.....: |
#2 |
another one...
#3 |
The PS is external, and build pretty much like the Zen V4 with the exception of the modulation part.
There are also the blue leds in the front but in the pics the amps are off |
#4 |
now , the rear panel: all connectors will be subjects to changes in "better parts " direction...
#5 |
Cute!
![]() Do you like the sound? Regards, Remco |
#6 |
... and a view of the sinks side...
#7 | |
Thanks , blank527 . Yes I like the sound veeeery much!!! |
#8 |
An eye on the inside...
On the small heat sink is mounted the Fet for the CCS; the capacitor is a nippon chemi-con 56000u -50V ;Necessarily I mounted some resistors in parallel to achieve the wanted dc point.I also introduced -see the Aleph X schematic-the famous "mills resistors" at a value of 22k. |
#9 |
The 2D pics do not appreciate a wiring sistem that is though enough clear
#10 |
the last one...
| constant current sources... | cathode_leak | Tubes / Valves | 10 | 29th March 2005 10:18 PM |
| Phase splitters: Constant current sources | BlackUnikorn | Tubes / Valves | 10 | 25th November 2003 02:44 AM |
| Constant Current Sources in Tube Amps | runeight | Tubes / Valves | 41 | 16th October 2003 10:17 PM |
| Aleph Constant Current Source | RobPhill33 | Pass Labs | 2 | 20th February 2003 02:54 AM |
| Page generated in 0.10036 seconds (77.90% PHP - 22.10% MySQL) with 11 queries |
