About possible Babelfish J interest
Old 24th September 2017, 08:08 AM   #251
2 picoDumbs is offline 2 picoDumbs  Australia
2 picoDumbs's Avatar
"If you leave this point unattached to some circuitry, an ideal constant current source will emit a small lightning bolt which will travel until it connects to something." Nelson Pass
Old 24th September 2017, 10:13 AM   #252
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
yup
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 24th September 2017, 07:44 PM   #253
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
I changed the source resistors to 0.33R 3W carbon composition (vs Panasonic metal thin film), and the bias is now about 1.63 to 1.68amps (the bias pot seems to have little to no effect (7 to 8 turns no effect) on actually changing the bias, only changing Source resistors did anything, is this normal?) The distortion went dow to 0.14% to 0.15% THD and the profile is predominant H2 and H3 about -15dB lower and nothing else - so this is good. Should sound very lush and vivid. Still well above what I think it should be at (circa 0.04% or less?). Should I just leave it alone now or pursue trying to see if it can go lower in THD?
About possible Babelfish J interest-babbelfish-amp-0-33r-testing-jpg
Zen Mod: what did the Spice simulations predict for the THD and the spectrum?
I am taking the data in a different location so the mains peaks and harmonics a little different.
Left Channel:
About possible Babelfish J interest-babelfish-fft-1-68amp-2-83vrms-8ohms-fft-left-ch-jpg
Right Channel:
About possible Babelfish J interest-babelfish-fft-1-63amp-2-83vrms-8ohms-fft-ch-jpg
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 24th September 2017, 08:21 PM   #254
Zen Mod's Avatar
TP3+R24 combined value is what's influencing Iq , besides voltage across R29
so - lesser ohms of TP3+R24 ,Iq lower ..... more ohms there , R29 is dominating
regarding THD ........ I would say that's good enough , not taking in account methodology of measurements ........ what's most important is that you confirmed K3 15db down vs. K2
Spice is ( as we know always enthusiastic) predicting something as 0.015% , 8Vpp@8R , with 0R33 biggies and app. 1A6 Iq
more oomph and THD goes even lower , but who cares
Old 24th September 2017, 08:44 PM   #255
Got Foam?
xrk971's Avatar
Thanks, ZM. I'll stop now and just enjoy it. Been listening for past couple of hours on my Scan Speak 10F/8424 tops plus RS225-8 FAST speaker. Very nice sound.
Old 24th September 2017, 08:52 PM   #256
Zen Mod's Avatar
now .... you can just contemplate what's possible with more sensitive and more efficient speakers .....
Old 24th September 2017, 08:54 PM   #257
Maybe run a square wave then if all good, you're all good.
The only thing I would suggest is if you have room for 2 x 200VA transformers I would put those in.
2 x 100VA is probably not really adequate for this amp. You could use those 100VA transformers on another amp or preamp.
Old 24th September 2017, 09:05 PM   #258
Zen Mod's Avatar
what ? those are 100VA Donuts ?
I'm using 250VA ones for dual mono ..... 200VA should be minimum
not saying that THD is going crazy because of that , at 1W , but things will go berserk up
or , if one likes Musical Fidelity approach ..... 80VA thingie feeding amp with 80W of dissipation
Old 24th September 2017, 09:11 PM   #259
Originally Posted by xrk971 View Post
My smallish 100w (per channel) trafos are sagging to about 20v rails under load.
It's advisable to use 200VA per channel bare minimum.
Determine what is the biggest trafos you can fit and go with those.
Old 24th September 2017, 09:26 PM   #260
Got Foam?
xrk971's Avatar
I got the smaller ones mostly as an experiment to see if the ground loop noise could be fixed, Did not want to plunk too much down before I knew that was the fix. I can use these for other projects now and will probably order a pair of 200VA's.
I have tried this with a 96dB/1w full range dual PA130-8 with an AMT super-tweeter and it does indeed come alive with more efficient speakers. It's really not sufficient for the 10F/RS225 FAST which really needs a 100w/ch amp to shine.
About possible Babelfish J interestHide this!Advertise here!
Babelfish J2 , just one package for sale Zen Mod Swap Meet 6 22nd April 2015 01:59 PM
For interest M Gregg The Lounge 0 26th September 2014 08:50 PM
Just for interest.. M Gregg The Lounge 0 17th July 2013 07:56 PM
Babelfish J combos Zen Mod Swap Meet 0 18th June 2007 11:18 AM
Maybe of interest... Ropie Analogue Source 2 20th April 2004 06:18 PM
