#81 |
Quick-Update: Mounted them back to back on a small heatsink, now I have a variation of 10mV around 0V DC. I guess that's good enough.
I have still quiet a variation between the power mosfets, but I understood from a comment Nelson made earlier in the forum that this should not be so important for the sound, only for the dissipation. So I gues I leave it the way it is and move on to the AC-Tests... |
#82 |
Noticed you had a query on snubbers for your LC... PSU.
Have you used the different PSU's with your Aleph X CRC.. vs LCLC.. and if so what are the differences? Am currently trying to decide on PSU to build 15V rail 8A bias 8 x O44 ( XA42). TIA Simon |
#83 |
You must have a very low impedance speaker whenyou use this combination 15V/8A.
I have not experimented with PSUs, I want to build the ultimative Aleph-X (according to my subjective standards) and I made extremly good expereinces with choke-input-PSUs in the past, so why experiemnt with cheaper solutions ? As reported, I have only 30Mv ripple in the rail after a simple LC-filter and I could bring it further own if required, but I have right now only 0,2mV rillpe at the speaker-output, so why go further ? |
#84 |
Short update: I am measuring an Ac current gain of 49 % with R12 = 1K, so I am wondering if the 1 % less than the optiomal 50% makes any difference and worth the hassle.
I made some measurements of the aquare wave response. I have the + connected to the signal generator and the - connected to ground. No caps in the input. 10pf and 220k as feedback resistor. scope measures in diffenrential mode (adding both channels with one inverted) across the 6 ohm resistor at the output. It looks pretty ugly though at the moment (see picture). Any ideas how to improve that ? |
#85 |
Correction: 100k feedback resistor.
Input-resistors: 10k in series and to ground . |
#86 |
OK, re-checked the whole equipment and found a problem of one output of the function generator - it gave 59V p-p into the Aleph-X...interesting that the Aleph-X was able to cope with that without going to hell...
...used now a different output with 3V p-p and now it looks not bad. Until which Voltage / Frequence did you get a perfect square-wave ? |
#87 |
Was realy enjoin this where is the rest?
Briliant tread Blitz will certanly came andy when I get there Tanks |
| Front firing vs down firing sub? | alex_g | Subwoofers | 32 | 22nd June 2010 01:34 PM |
| Down firing vs side firing? | Tee-Bruce | Subwoofers | 36 | 26th August 2009 07:32 AM |
| Aleph DIY x100 and Wilson Audio-low impedance problem. | elviukai | Pass Labs | 11 | 9th March 2006 07:36 PM |
| Woofer: side firing pair vs front firing? | tcpip | Multi-Way | 13 | 9th September 2005 03:13 PM |
| Please help! Firing up new Aleph 5... | Lucas_G | Pass Labs | 5 | 14th February 2003 08:38 AM |
| Page generated in 0.10932 seconds (72.03% PHP - 27.97% MySQL) with 11 queries |
