Suitable volume pots for DIY Pass Pre amps
Joined 2003
Havent bought any volume Pots in a while, I used to buy Noble pots for most projects, but apparently they have stopped making them. The more expensive TKD seems to have suffered the same fate. I have located a few 100K Noble units, but need a 50K unit for the BA-3 as pre amp.
For the B-1 I used the recommended PEC pots, but wanted something a little more elegant for the BA-3 as Pre amp I am finishing up. The Goldpoint that 6L6 used in his build was nice, but a little rich....may have to save for it as I am not finding much else out there.
What are the Pass builders out there using for your volume pots? Any help in this regard would be appreciated.
Russellc
I'm spoiled
either that , or 10K audio taper from radio mix deck
if not these , cheap Lorlin lookalike switch based attenuator with smd resistors is best bang for the buck - fleabay is full with those
AVC looks sweet, even more $ than Goldpoint! Looks like no cheap way to do this elegant, I'll search Ebay for value dreck...can always replace later with more elegance ($)...
Thanks,
Russellc
If you are going to build your own, be sure you get a schematic of the pin in and outs by the manufacturer.
Bought one from partsconnexion.com and one miss wire ruined 6 hours of work. Yes, I did test for in and out connections. On this build, the pins were off-set and the first position was actually physically the second position. What a mess! It made no sense. To boot, the switch had two sets of inputs.
Goldpoint has surface mount switches.
4POLE 24 Step Attenuator Volume Control Pot Log A 25K 25kA Stereo Potentiometer | eBay
Iam using on of these in my ba3, unbalanced. Its worked for 3 or 4 years, had it in multiple preamps, only cleaned it once. Its big though if size is an issue.
I see its a four pole. I see your pre was unbalanced did you just ignore the other 2 channels, and leave them unconnected? Otherwise, how did you wire it to your 2 channel pre? Thanks guys,
(maybe I'm confused, I am assuming "4 Poles" means four channels? If its only 2 then that clears things up...)
Russellc
No one mentions MUSE...as in XP 30 ?
'course as ZM says ...not best bang for the buck....maybe ...if you take into account the price of matching a bunch of Dales or other to make your own.
But...mainly because not easy to get.
