mosfet matching wide variations/swings
Joined 2000
Purchased 20 irfp140 and 20 irfp9140 mosfets.
Matching them has been less than fun.
Setup:
Mastech 30v 10A power supply
Large-ish blank anodized heat sink 4x6x1 inch
Sheathed alligator clip leads
Silicon iso pad.
15v, 60 ohm power resistor .13A
I thought I was getting good readings but if the dmm lead are touched or if I reach over the setup, the voltage swings but never settles to it was originally.
If i re-test, the Vgs is different.
If i touch the heat sink the voltage changes.
I don't trust the readings so I can't continue with the build. I don't remember it being this difficult.
I tried 4 meters and different meter leads.
How is matching done properly?
Joined 2000
Gate to drain
15v to drain
Ground to source pin
Joined 2000
You must keep Tj at the same value for every test/DUT, that is really difficult !
Yes, I imagine it's difficult keeping accurate temps. I left the setup out over night with the mosfets on the same table, Closed a vent that pushed air over that work area. That's the best I could do. I wasn't going to measure Tj. :)
the readings were completely different for the N-Ch fets. Some read 7.xxV other times 5.xx, but with the gate resistor, every fet was in the 5.1xxV range.
Interestingly, the P-ch fets had closer readings with or without the gate resistor, even a day later and with different room temps.
Thanks.
Vince
