Firstwatt F5, some Problems... - diyAudio
Old 30th March 2015, 10:04 PM   #1
Default Firstwatt F5, some Problems...
I got it running. The sound is very good, but there is some hum.
My setup: 800VA transformer, 4x 47000uF, 2 Bridge rectifiers, CRC as in manual.
The switch on is with a switch-on-unit (resistor, delay, relais), the ground connection with 10R, 2Diodes from a bridge and a small film cap (100nF or so...)
The two supply voltages meet in a single point - the copper bar.
If I switch off the transformer, the hum immediately stops. If I source the power with the lab supply, there is no hum either. I connect the lab supply ground as well to the 220V inlet ground.
How can I solve the humming trouble?
Regs, Dirk
Old 30th March 2015, 10:16 PM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
those inner red and black wwires , going from bridges to first caps - re-route them to middle of the ground bar
if needed , rotate toroid - maybe there is some stray field , too
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 30th March 2015, 10:28 PM   #3
In addition, Click the image to open in full size. so as to avoid ground loops, the heatsinks also need to be earth grounded.
Old 30th March 2015, 10:52 PM   #4
@ZenMod: Changed wires, no effect
@prooptiki: Added Earth from copper bar to cooling fins - no effect.
Any Ideas???
Regs, Dirk
Old 30th March 2015, 10:57 PM   #5
Another Problem: I cannot rotate the toroid: It's fixed with 2 screws!
Old 30th March 2015, 11:22 PM   #6
fdlsys is offline fdlsys  South Africa
fdlsys's Avatar
Are you sure it's not the transformer itself "humming" mechanically?
Old 30th March 2015, 11:38 PM   #7
There is a slight mechanical hum. But a much bigger electrical hum. With speakers, it's 2 or 3 times louder.
Old 30th March 2015, 11:58 PM   #8
Zen Mod's Avatar
ok
without nothing on input - what's happening ?
Old 31st March 2015, 12:04 AM   #9
removed cinch cables, still the same.
Hmmmm....
Old 31st March 2015, 12:25 AM   #10
rayma is offline rayma  United States
Is the metal plate (under the pcb on top of the toroid) grounded, or connected to the pcb electrically in any way?
Exactly how is the toroid mounted - you said there are two screws?
Switching between Firstwatt F5 and AlephJ lykkedk Pass Labs 24 7th February 2015 08:56 PM
FS : diy clone FirstWatt F5 prooptiki Swap Meet 4 12th March 2014 10:08 AM
FS: Pass FirstWatt F5 assembled PCBs rookakoma Swap Meet 3 26th April 2013 05:44 PM
WTB: Firstwatt F5 parts kit and/or PCB Destroyer OS. Swap Meet 2 20th February 2013 07:02 PM
FirstWatt F3/ F5 Clone GB suds Group Buys 39 22nd February 2011 08:10 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright ©1999-2016 diyAudio
