NEW Aleph-X calculation sheet: AXE-1 NEW Aleph-X calculation sheet: AXE-1 - Page 2 - diyAudio
Old 30th January 2004, 04:04 PM   #11
jam is offline jam  United States
jam's Avatar
Old 30th January 2004, 07:04 PM   #12
wuffwaff is offline wuffwaff  Netherlands
wuffwaff's Avatar
David,
just up the bias and the amp will double into lower impedances (untill again the current limit is reached).
You can even test 60A of bias without anything getting hot
and thanks for all the compliments!!!!!
william
P.S. Im thankfull for any constructive critisism or ideas how to improve AXE-1. I will look at these and when theres enough new stuff there will be an AXE-2.........
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 30th January 2004, 07:46 PM   #13
roddyama is offline roddyama  United States
diyAudio Moderator Emeritus
roddyama's Avatar
1 or 2 decimal places in B16 and B75
Rodd Yamashita
Old 31st January 2004, 02:39 AM   #14
MikeW is offline MikeW  United States
MikeW's Avatar
Default Total bias question for one channel
If total bias is 4 amps for one channel. There are 4 outputs. One amp per output. The current out of the power supply shoul be 2 amps from the positive rail and 2 amps from the negative rail. So total power from the transformer should be 4 times the rail voltage. Is this correct?
MikeW
Old 31st January 2004, 04:25 AM   #15
jlm is offline jlm  France
Hello,
Congratulation for your spreadsheet.
I constructed, there are some months, 2 monophonic Aleph-X,
http://www.passdiy.com/gallery/alephx-p4.htm
The schematic is the one of Blitz slightly modified with 24 IRFP240 MosFets.
Voltage: 31V
Bias: 8A
Power 200 Watts / 8 ohms
With AC current gain: 50%
125 watts / 4 ohms
62 watts / 2 ohms
31 watts / 1 ohm
With AC current gain: 60%
200 watts / 4 ohms
100 watts / 2ohms
50 watts / 1 ohm
On the forum, Mr. Nelson Pass says that AC current gain = 69%, it is too high
It is the particularity of these circuits, the power decrease if the impedance of the speakers decrease. I wonder if it is true with the XA200 of PassLabs. There is perhaps a trick.
On the XA-200 Owners Manual, it is written: Max Output Current: approx. 15 A
How to have 15A with a bias of 8 or 8,5A without overshooting 69% of ac current bias?
With my Renaissance 90 INFINITY speakers (87dB and very low impedance 1 to 2 ohms mini) in a large room, the DC protection circuit of my Aleph-X clones operate. I would need more of power on low impedance
If someone has a solution!!!
Best regards
jl.m@tele2.fr
Old 31st January 2004, 06:46 AM   #16
wuffwaff's Avatar
Mike,
Im not shure I understand your question but power from the transformer is total bias multiplied by total voltage (V+ and V-).
For +10V -10V and 10A this gives 20V x 10A = 200W
This is the power that is constantly drawn.
Jlm,
there is no trick. The specs from the AX-200, 160 and the Alephs are a bit confusing. The only way to get a given peak output current is to have enough bias or to up the ac-current-gain.
The infinity is probably one of the worst loads for the Aleph (X or not) So here I would lower the voltage to 20V and up the bias the same amount so the total dissipation stays the same for example 20V, 12A 60% gives
81 watts 8ohm
162 @4Ohm
225 @2Ohm
William
Old 31st January 2004, 10:19 AM   #17
MikeW's Avatar
Would that be 2.5 amps or 5 amps per MOSFET?
MikeW
Old 31st January 2004, 11:19 AM   #18
wuffwaff's Avatar
That would be 10A in total,
how much per fet depends on the amount of fets you use,
with 4 fets it would be 5A per fet, with 8 2.5A etc. etc.
william
Old 31st January 2004, 03:53 PM   #19
MikeW's Avatar
4 MOSFETs with 5 amps each is 10amp total bias?
MikeW
Old 31st January 2004, 05:16 PM   #20
wuffwaff's Avatar
Mike,
if you take 100 1 Ohm resistors and put them all after each other (in series),
then you take a power supply and put 100 Volts across the first and the last of the 100 resistors,
there will flow a current of 1A through each resistor,
how much is the total current now
100A?
or
1A?
William
NEW Aleph-X calculation sheet: AXE-1Hide this!Advertise here!
looking for old data sheet unclejed613 Parts 3 13th May 2007 06:35 PM
1/2 sheet of ply project? Phergus_25 Full Range 5 20th March 2007 11:14 PM
I need calculation formula for Aleph quyda Pass Labs 2 29th January 2006 09:39 AM
op amp/dac data sheet help Smiffy Parts 11 13th December 2004 08:14 PM
Copyright ©1999-2017 diyAudio
