New PassDIY Headphone Amp (now available)
Old 5th November 2017, 12:25 AM   #861
jameshillj is offline jameshillj  Australia
Are the values of the 22uF caps critical, especially the one to ground on the -ve input of the IC?
Any benefit in using bigger/polyester type caps here?
Old 5th November 2017, 05:09 AM   #862
wayne is offline wayne  United States
Auburn
wayne's Avatar
No the cap values are not that critical. Mostly just values we stock.
wizards assistant
Old 7th November 2017, 08:22 PM   #863
Tix88 is offline Tix88  Italy
Hi guys,
I'm starting to mount the board, I have some questions
I am using red led 3.5mm, r9-r10-r13-r14 empty, c10-c8 220uf, r16-22-29-32 10ohm, so is it correct?
Old 7th November 2017, 09:37 PM   #864
Auburn
wayne's Avatar
Yes that is correct.
wizards assistant
Old 8th November 2017, 01:09 AM   #865
Russellc is offline Russellc  United States
Originally Posted by drpro View Post
Swapped the AD823 with a Sparkos SS3602. Has turned out to be a really nice match with the rest of the parts. Voices are pleasant, mids are present without being harsh, the highs are crystal clear and soft to the ears. Definitely worth a listen. To my ears really makes all of Wayne's work shine.
Who is a recommended source for the Sparkos SS3602 devices? Quick search turned up Ebay, who absent a trusted seller I do not trust.
I take it they are quite a bit larger than the AD823 units? Any pics of how you wired them?
Russellc
Pass B-1 preamp, Pass BA3 preamp, Pass F-5 Amp, Pass F-6 Amp, Pass BA-3 Amp, Pass M-2 amp, Pass Aleph J amp, Pass Pearl 2 Phono pre
Old 8th November 2017, 01:47 AM   #866
drpro is offline drpro  United States
Straight from Home - SparkoS Labs Inc. Russell. I will take apart my HPA tomorrow and snap a pic. Sparkos sends a DIP spacer so it fits nicely above the two caps on either end of the socket.
Old 8th November 2017, 06:12 AM   #867
Thank you for the reply. What does it mean to use a 17.4V instead of 15V power supply?
Old 8th November 2017, 05:08 PM   #868
Auburn
wayne's Avatar
Not much difference a bit more power output but hardly matters for headphones. The heat goes up in the output stage and less heat in the regulators. I like the LEDs as power indicators.
wizards assistant
Old 8th November 2017, 06:01 PM   #869
Hi
Here's my board almost complete.
I have used dale resistor ptf65 and rn60 & rn 65,for capacitors panasonic fc , nichicon fine gold, and Mundorf supreme evo oil, resistors are all 0.1%, matched led.
I'm waiting for 2sk / 2sj matched and then we can go to the test.
For the op-amp try OPA2228PA and OPA2132PA and maybe later discrete OPA
Old 8th November 2017, 06:16 PM   #870
Great, thanks for the info, I need to finish mine up!
Russellc
New PassDIY Headphone Amp (now available)Hide this!Advertise here!
Testing an amp with dummy load, can hear music coming from inside the amp. ElectroAcoustic Solid State 11 10th December 2014 10:43 PM
Planars dream amp maybe coming soon n3szd Planars & Exotics 8 22nd September 2014 10:12 AM
No sound coming from Amp Shido181 Car Audio 9 1st August 2014 07:05 AM
no sound coming out of amp tony711 Car Audio 4 9th June 2010 05:47 AM
The New Sonic Amp is coming Pano Class D 1 11th November 2005 11:37 AM
