New PassDIY Headphone Amp (now available)
Old 13th April 2018, 02:53 AM   #1081
Frazzled is offline Frazzled  Canada
Frazzled's Avatar
WOO HOO just purchased 2.
Thank you!
Anything worth trying is worth failing at once or twice.
Old 13th April 2018, 07:12 PM   #1082
wayne is offline wayne  United States
Auburn
wayne's Avatar
Thanks 6L6 for all your work on this. My gets used quite often.
wizards assistant
Old 14th April 2018, 10:42 AM   #1083
osscar is online now osscar  Latvia
osscar's Avatar
Originally Posted by 6L6 View Post
Osscar - Wonderful! A beautiful construction!
Looking forward to hearing news of it's operation. Post more photos if you have them
Whammy is finally finished!
I turned to the dark side (with a blue LED of course):
internal part( There was a small hum on the left channel from the transformer - I made a mu-metal shield)
sounds very good, the bottom end is very fast!
Bias 100mA, Irfs, BB OPA 2604 (original), all 22uf non-polar+film caps.Rails: +-17V. heat sinks - 55 Celsius. offset - 1mV and 0,1mV
My DIY so far: two Leach amps, Pass AB100, Pass F5, B1 buffer, Hiraga le monstre, two LM3875, LM1875, OPA549, 6C33C SE, GU32 PP, 6p3c-e PP, Marsh headphone amp.Phono - OBH-8se, Pacific RIAA, inDiscreet Phono, Whammy headphone amp.
Old 14th April 2018, 01:08 PM   #1084
6L6 is offline 6L6  United States
6L6's Avatar
Beautiful! Thanks for the photos!
Old 14th April 2018, 02:08 PM   #1085
osscar's Avatar
Thank you and others who are involved and made this project available to everyone.
I like the optocoupler bias circuit - no adjustments, it works from the first start !
Old 14th April 2018, 03:12 PM   #1086
WalterW is offline WalterW  Netherlands
Wow! Nice work Osscar. Nice PCB's and chassis.
Pass F5, F5Tv3, ACA, Aleph J, DDDAC1794, DCB1, BA3-preamp, VFET CSX1, Pass F6, Pass M2-HPA, VFET-X balanced, Pass J2
'If you see me talking to myself, don't worry. I'm getting expert advice'
Old 14th April 2018, 03:22 PM   #1087
osscar's Avatar
thank you, they are not as perfect as industrially produced, but it's DIY after all. (I decided at last to put parallel resistors in PSU CRC to reduce dissipation ..resistors are not parallel in - there was no pads for that )
Old 27th April 2018, 06:54 AM   #1088
pelayostyle is offline pelayostyle  United States
In the planning stages for this build and I really want to use an AD8620 I have laying around. Specs show max dual-supply voltage at 13V. It looks like its R35 and R36 need to be changed to drop the voltage a bit but not sure what values to try. Can anyone help? Thanks!
Old 27th April 2018, 06:12 PM   #1089
Auburn
wayne's Avatar
You could use a 15 volt transformer and 12 Volt regulators.
If you use 15 Volt regulators the resistors would need to be about 330 Ohms and I don't know if that is the best idea.
wizards assistant
Old 12th May 2018, 11:48 PM   #1090
nzlowie is offline nzlowie  Australia
I've been looking for a really nice sound ding low power amp to drive my horn's, could I use something like this or would this struggle to drive 8 ohms?
New PassDIY Headphone Amp (now available)Hide this!Advertise here!
Testing an amp with dummy load, can hear music coming from inside the amp. ElectroAcoustic Solid State 11 10th December 2014 10:43 PM
Planars dream amp maybe coming soon n3szd Planars & Exotics 8 22nd September 2014 10:12 AM
No sound coming from Amp Shido181 Car Audio 9 1st August 2014 07:05 AM
no sound coming out of amp tony711 Car Audio 4 9th June 2010 05:47 AM
The New Sonic Amp is coming Pano Class D 1 11th November 2005 11:37 AM
