1'ST edition Aleph P
Old 14th March 2015, 03:17 PM   #1
waltroman is offline waltroman  United States
Default 1'ST edition Aleph P
These question may very well be left for the factory but since this is Saturday and my Aleph P arrived last night I thought I would start here.
I purchased a Aleph P serial #003 and upon first listen there was noise almost like a ground loop or improperly grounded circuit. No hum. Also I was getting two sources playing at once. I pulled the top and found the two wires that would I believe to connect to the center pins of the RCA's right next in line from the output jacks off and hanging (damn FEDEX). One other wierd thing is that someone apparently wanted two sets of outputs so they wired jumpers from the output jacks to the same center pins of the input jacks that had the wires that came off. *** That is why I had two sources playing at once. **** I will fix this.
The only manual for the P on the pass website is for the revised version and some changes were made.
This preamp has way too much gain for me, too much to be able to be use. The later revision has changes made to the Master volume control to allow it to be set in a number of positions (5 normal and 5 positions that are -12db down.) Then the separate right and left controls do the fine tuning. My preamp has a more conventional ladder volume control. The separate volume controls for L & R are a 1K conductive plastic pot.
If I need more attenuation can I use a higher value pot in its place, or add a resistor in line?
Walt
Old 14th March 2015, 10:56 PM   #2
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
this one ?
increase R115 to decrease gain
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 14th March 2015, 11:53 PM   #3
Much thanks, will have a good look see tomorrow. If I want to drop 6db whay would a good value be? 1K to 2K?
Walt
Old 15th March 2015, 12:04 AM   #4
Zen Mod's Avatar
I'm lazy for calc now ......... but let try with some simple crude logic
gain span is from 8 to 14db , with max to min value of P101
considering its value is 1K ,gain change is 6db .......... try to increase R115 exactly for 1K .... to 1K5 (1K6 more common value , also good)
Old 15th March 2015, 12:17 AM   #5
Thanks again.
Old 15th March 2015, 12:23 AM   #6
Zen Mod's Avatar
ya owe us some porn
Old 15th March 2015, 04:17 AM   #7
Just finished up with a rough week, off tomorrow, maybe pics then. I have never done pics here, should be able to figure it out. Spent a few hours listening and the preamp is awesome.
Old 18th March 2015, 11:58 AM   #8
I have been on the phone with the techs at Pass. The more I look at my copy of the P it does not match what became the first production units. I asked about increasing the value of R115 or changing the pots to 1.5K or 2.0K units they indicated that higher resistance would allow higher noise. They offered a better way would be to jumper a 1k resistor across two 750 ohm 3 Watt resistors except I cannot find any 750 ohm 3 watt resistors. Do not know how to copy the pdf to here.
Every schematic I have seen is loaded with 1uf and 10uf caps and none here. I am not sure if this preamp is cap coupled unless it uses one of those large 1000uf caps. This may have been one of the original prototypes.
Any idea the location of resistor R115? Should it be one of the 3 watt resistors?
Here is a the ad where I bought the preamp. It has a pic of the inside. Clicky to expand the pics.
Pass Labs Aleph P Preamp Non remote version - Audio Asylum Trader
Old 18th March 2015, 01:01 PM   #9
Zen Mod's Avatar
there must be some miscommunication - I can't see how increasing amount of source degeneration can increase noise
however , it seems that is early specimen (Ser. No. 003) , mosfets (IRF240) as active elements and bipolars (MJE) in PSU reg role
it's probably time for Papa to chime in ....... but - if schematic is in any way similar to one we have , you can make this :
look at picture I attached , and two red arrows ; desolder one red wire from right pot , solder 1K resistor (small one of 250mW is good enough ) to pot lug , solder wire to free end of resistor .
do the same on other pot with white wire
regarding output caps ..... I'm not seeing any other than big honking electrolytics ...... but that's separate issue ( bypass them or not , recap entire thingie or not)
Old 18th March 2015, 02:13 PM   #10
Zen Mod's Avatar
I remember some amps (from other "factories" ) made with lesser hardware .....
1'ST edition Aleph PHide this!Advertise here!
Hx-Home Edition and Hx Mini Edition will be released December, 24th destroyer X Solid State 57 1st June 2017 06:05 PM
What are your opinions of the ST-70 and St-120 ElCid79 Tubes / Valves 51 10th March 2015 11:48 AM
my 1'st time changing an xstr, and my 1'st post here :) Jave Solid State 12 2nd July 2011 11:58 PM
St 35 or St 70? scetoaux Tubes / Valves 13 19th February 2011 06:18 PM
College-proofing an ST-70 (aka autobias+ST-70) antiquekid3 Tubes / Valves 15 13th June 2010 04:37 AM
Copyright ©1999-2017 diyAudio
