Officially Class A
Officially Class A
Old 15th March 2002, 11:46 PM   #11
Jakeh is offline Jakeh
"The 1/2 inch thick front panel is a welcome addition to any audiophiles system"
snort.
Old 16th March 2002, 02:28 AM   #12
AudioFreak is offline AudioFreak  Australia
Warp Engineer
On Holiday
AudioFreak's Avatar
Officially Class A
Originally posted by grataku
Muralman,
don't bother. Noboby here cares.
I wouldnt say that grataku, I would like to see that muralman come to understand why the accusations made about this amplifier are most likely false.
Old 16th March 2002, 04:21 AM   #13
muralman1 is offline muralman1
I don't care one way or another. The builder insists his amp is Class A. This assertion has met up with a lot of resistance elsewhere. I was hoping for some insight here on how the 200 watt Llano could be made that way. Since The Llano is the only amp around that goes class A all the way without getting hot and with what looks like less cooling apparatus than the 20 watt Class A Pass 150, It seems to me, a builder of class A amps would be curious. this amp is a single triode leading to solid state Mosfets. Someone has said it is push pull. The builder gives credit to advanced Mosfets.
Has anyone looked at it yet?
Old 16th March 2002, 07:11 AM   #14
Joe Berry is offline Joe Berry  United States
muralman1,
I haven't seen (or heard) the Llano, but here is one possibility. Note that the driver stage contributes some output current and could therefore technically be considered part of the output stage. As long as the driver stays in class A -- and it will do so even while driving the outputs in class AB -- one could claim that the output stage works class A to full output.
Please, I am not putting words in anyone's mouth -- just wanted to offer one possible explanation. BTW, this approach has been used in the past by other manufacturers of "class A" amps.
Old 16th March 2002, 04:38 PM   #15
Thankyou very much, Joe. You are right about manufactures using the accolade Class A loosely, to say the least. Way Back When, I had a Denon that claimed to be "optically" class A. I bought it.
Old 20th March 2002, 12:18 PM   #16
Super_BQ is offline Super_BQ
Super_BQ's Avatar
Send a message via ICQ to Super_BQ Send a message via Yahoo to Super_BQ
Default Plinius makes the same claim!
Thanks for your input Joe Berry,
Another popular high-end brand that seems to **** ME off is Plinius.
Last year I picked up a brochure of their SA-250 amp and the specs say when bridged, the sucker can do 900 watts into an 8 ohm load! In big red lettering across the brochure it says "CLASS A".
Taking a quick look at the SA-250 manual which is downloadable at http://www.pliniusaudio.com/dow/dow.htm
Looking at Page 7 it talks about Bias switching (those familiar with Plinius their SA amps can be switchable between Class A and Class AB modes). Taken from page 7:
"The current required from the mains supply in BIAS A is approximately 1,000 watts, similar to a
small electric heater. The amplifier should not be connected to a wall outlet that is shared with.... "
So right from the sheep's mouth... we're talking about a transformer that draws approximately 1 KVA.
With some simple math we take 900 / 1000 and we get 90% - so what we have is a 90% efficient amplifier? Give me a break Plinius! Even sheeps don't poop out more poop than a male cow.
Even worse, the manual quotes on page 20 explains, "Why Class A is Better".
It's sad to see how hifi manufacturers have (and still today) get away with feeding the public with so much BS. Just as bad as the hifi magazine reviewers, even the definitions of electronic terms BECOME misleading.
BQ
Old 20th March 2002, 04:47 PM   #17
BQ,
Plinius' claim actually may be accurate, at least for normal (unbridged) operation. Assuming that it draws 1,000W from the wall at idle in class A mode, each channel is probably dissipating about 400W, implying a true class A operating range of about 200W, and perhaps the full 250, depending on the bias circuit.
Just eyeballing it, I'd guess that the heat sinking for each channel is at about .1 degree C/W, which would give a 40 degree C rise in temperature for class A operation -- probably still safe for the output devices, but way too hot to touch comfortably.
It's true that bridged operation in itself doesn't increase the range of class A operation beyond what each channel can deliver on its own. If Plinius (or anyone else) suggests that their amp works class A at levels beyond half the amp's idle dissipation, they really ought to offer some defense for the claim.
BTW, I tried earlier to locate the idle dissipation spec for the Llano, but was unable to find it on their web site. Is it there somewhere?
Old 20th March 2002, 05:22 PM   #18
Dustin Haug is offline Dustin Haug
Why is this? I'm not arguing just curious.
Old 20th March 2002, 06:15 PM   #19
Dustin,
The range of class A operation is mainly determined by the amp's idle current. While bridging allows twice the output voltage swing across the load, each channel in the bridge still transitions from class A to AB operation at the same point in its output current swing.
Take for example a 100W push-pull class A stereo amp in which each channel idles at 2.5A and can develop 40V peak across an 8 ohm load. The amp is class A because the current needed for 40V across 8 ohms is 5A, which is twice the idle current. Given linear operation, each side of a push-pull output stage can deliver twice its idle current before the other side shuts off.
If we now bridge the two channels, we can get up to 80V peak across an 8 ohm load. This requires up to 10A output from each channel, but since each channel still idles at 2.5A, it still transitions from class A to AB at 5A output, at which point one side of the output stage shuts off while the other side delivers the 10A to the load.
Hope this is clear -- let me know!
Old 20th March 2002, 06:27 PM   #20
Default More on the Llano
Reviewing the info on the Llano web site, I noticed mention of a passive bias circuit. This suggests that Llano is not (any longer) using Hexfets or other trench-type mosfets that need some kind of temperatrure compensated bias circuit, such as the one shown in my schematic above.
Llano may instead be using lateral mosfets, which not only don't need a temperature compensated bias, but also tend to turn off very slowly, giving them an inherent quasi-class A behavior when used in complementary push-pull stages. It may be that the Llano design is leveraging this behavior in making its claim.
Officially Class AHide this!Advertise here!
I now officially hate M-Audio SY Everything Else 95 3rd August 2007 06:12 PM
How about a round-up of Class A kit power amps, or collectable vintage class A? Brisso57 Solid State 4 14th February 2007 11:30 AM
