Old 28th January 2004, 04:42 PM   #1
CheffDeGaar's Avatar
Question TSH4131 And "X" ?
Question for X-perts
I just came upon TI's THS4131 datasheet , and a question arose in my little head. Considering the attached image, in which I melt two images from the datasheet, and comparing it with this post from stefanobilliani in the forum, I couldn't resist joining the two. The simplified schematic of the THS4131 shows a diff amp with a folded cascode with active loads, and the little application schematic shows the feed back resistors tie the "+" (resp. "-") inputs to the "-" (resp. "+") outputs, just like the x-bosoz linked above. So the eternal question... :
Does it qualify as "X" ?
And the immediately following q. : Why do I always ask stupid questions ?
/Cheff - Falling feels like flying, until you hit the ground
Old 28th January 2004, 07:32 PM   #2
The one and only
Nelson Pass's Avatar
I would say that there's enough there to possibly constitute
patent infringement, not that I would bother with it.
Old 28th January 2004, 07:43 PM   #3
Default Re: TSH4131 And "X" ?
Originally posted by CheffDeGaar
The simplified schematic of the THS4131 shows a diff amp with a folded cascode with active loads, and the little application schematic shows the feed back resistors tie the "+" (resp. "-") inputs to the "-" (resp. "+") outputs... Does it qualify as "X" ?
This is basically the same approach taken in the Hadley 622, and later, in David Hermeyer's "Electrostatic Amplifier Mk2" (Audio Amateur 3/1973). All of these differ from the Pass X circuit in that they add a third feedback loop to cancel common mode error. One might question whether this CM error is worth fixing in an amplifier designed for listening, as according to Hermeyer, it (merely) leads to some added second harmonic when the output is loaded asymetrically.
Old 28th January 2004, 08:45 PM   #4
The one and only
It would be the folded cascode that probably would turn
the legal argument, as the precedent hasn't been seen for
that, and it is part of the patent claim structure.
Old 29th January 2004, 10:42 AM   #5
Thanks for replying, Mr Pass ! And I should have seen it form the start : it's written in the image (see attached picture)
BTW, this IC exhibits nice figures (slew rate, BW, noise, etc... Product folder here) It's tempting trying to build something and listen to it... I've seen this IC used as a balanced IV Converter in the Bel Canto Dac 2, wich was highly praised when it appeared...
Joe, thanks for the references. From an extreme point of view, the "servo loop" can be ommited and replaced by a mere voltage source biasing the lower BJTs to maintain a null DC offset at ouputs. But, in my very limited experience , such a fixed biasing for a folded cascode topology is critical, since this topology is very sensitive to the bias...
Old 29th January 2004, 12:24 PM   #6
FWIW, I think that the added third feedback loop is an interesting conceptual difference, but I doubt that it could be used by itself to invalidate a claim of infringement. If my understanding is correct, a circuit infringes a (US) patent if it is found to include the latter as a subset.
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
What Does Fostex "Rated Input" and "Music Power" mark02131 Full Range 3 2nd January 2007 08:31 PM
Fostex "rated input" and "music power" hugz Full Range 12 16th March 2006 04:33 PM
Some final pics of "Stacks" revisited and "Askew" with stand Andy G Multi-Way 2 3rd February 2005 06:07 AM
Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? Ignite Multi-Way 3 18th November 2001 08:42 AM
Page generated in 0.14634 seconds (66.16% PHP - 33.84% MySQL) with 11 queries
