another newbie question -
can i convert unbalanced output of my preamp to balanced by inserting a 1:1 audio transformer at the input of the SOZ amplifier? i'm having trouble simulating this, so i was wondering if any of you experienced folks had an opinion? also, an unrelated question: is it ok to convert a regulated +/- 40VDC power supply to a -20-0-+20VDC power supply using a couple of caps and resistors? (see figure below) thanks |
#2 |
Hi psarin
An inputtransformer is not a good solution here, you should look for something else. I used a linedriver (opamp) from burrbrown until I had finished my balanced zenlinestage. This is the powersupply for for my SOZ. It works rearley great! This supply gives you +19, 0, -19 volt. The 46 v is directly from the diode bridge. The regulation is from Ciuffolis Powerfollower99. http://www.geocities.com/ResearchTri.../my/index.html
Henrik |
#3 |
The one and only
Jensen Transformer in Hollywood makes a
wonderful line level balanced transformer for this. |
#4 |
...And wich is?
Let's make something special |
#5 |
Is there a sonic improvement to externally converting an unbalanced source to a balanced source using methods, like the ones mentioned here?
I'm wondering if a balanced pre-amp or amp benefit from "balancing" an unbalanced upstream signal in this manner, ather than using existing unbalanced inputs? -David |
#6 |
I've found that jensen JT-11P-1 may have the caracteristics we are looking for, i wonder if is this that Nelson was thinking of, i suppose that this is the one used by jeff rowland d.g.
#7 |
The one and only
Responding to the last two posts, I believe the answer is yes
in both cases. |
#8 |
Another way of unbalanced to balanced conversion is to utilize BB DRV134 chip. I know someone in Taiwan made a small kit available. The circuit looks simple enough!
Thomas This is the image of that conversion: |
#9 |
and the real kit looks like this:
#10 | |
Another option would be to use an output transformer to balance the output of the source component. The JT-11-DMCF or DMPC would be a good choice. However if the source's output is capacitively coupled, you need to make sure it's got several hundred uF of capacitance in order to avoid low frequency resonance (which would result in some response peaking) due to the much lower primary inductance compared to input transformers. se |
| Balanced & Unbalanced input with LM3886 chipamp.com | JohnnyP00 | Chip Amps | 5 | 17th January 2010 02:33 AM |
| Unbalanced to balanced input conversion? | SQLGuy | Solid State | 53 | 19th October 2009 01:39 AM |
| Line input transformer for unbalanced to balanced conversion | okapi | Chip Amps | 23 | 12th January 2008 05:29 PM |
| ESP 101 with balanced/unbalanced input | Cloth Ears | Solid State | 2 | 17th June 2006 11:12 AM |
| converting and unbalanced in into a balanced input | joyfulstudios | Parts | 2 | 12th June 2005 12:41 AM |
| Page generated in 0.10985 seconds (80.19% PHP - 19.81% MySQL) with 11 queries |
