Threshold's - diyAudio
Old 27th January 2015, 12:55 PM   #1
Default Threshold's
After several days reading about Threshold, Pass Labs and ,, papa'' Nelson Pass I decide to buy a Threshold SA 3 amplifier and Threshold Fet Nine preamplifier, both in very good condition from first owner. My question is if 2000 is a fair price for both? In Europe!
Old 27th January 2015, 03:39 PM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
good amps
however , only rest of market offer can give you proper answer
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 27th January 2015, 07:22 PM   #3
jvhb is offline jvhb  Denmark
2k € sounds reasonable to me, if they are both in good condition.
Old 26th July 2015, 04:41 PM   #4
Hello again! I am using this Threshold's for more then half year and I am very happy with them, it sounds exactly as I want, warm and clean sound ,,holographic''. I order Audioquest Colorado interconnect and Audioquest NRG 10 power cord for them and I am very curious how the sound is changing!
In this week I got a problem, when I start my turntable (Denon DP-47F) I found the right channel almoust missing, sound was very low. I checked the output of turntable with another system and both channels are ok. The other inputs on Threshold FET nine preamplifier are normal, I use CD almost everyday, so was a surprise when I try to listen some LP and found this problem. If I can get a help with a drawing for FET NINE or some advices I will be grateful! I mention I have knowledge about electronics and I wont to fix it by myself.
Old 26th July 2015, 05:19 PM   #5
Zen Mod's Avatar
later tonight will post some info
Old 26th July 2015, 07:21 PM   #6
Zen Mod's Avatar
it's here :
Treshold Treasure ?? while Papa was there : FET 9 | Zen Mod Blog
Old 26th July 2015, 07:49 PM   #7
Thank you! I will be back with any progress in my troubleshooting!
Old Yesterday, 07:38 PM   #8
Today I open my FET 9 and surprise... on phono stage it was some job before! On both channels I can see new bonding on transistors, capacitors and resistors like somebody try to fix a similar problem in a past. On right channel witch I have low signal Q5 and Q6 are BC 556 instead A42 ( related to the drawing that I got). Comparing with left channel some voltage are different start with first amplifier stage 2N5566 looks like is not working on the right range. I try to move the gain jumpers on MC or MM but are in correct position. I adjust the supply voltage to +/-18.3VDC ( lower value for negative voltage on potentiometer) If I can get some measuring points on FET 9 drawing will be a big help for troubleshooting!
Old Yesterday, 08:12 PM   #9
Zen Mod's Avatar
measure what you have , edit schematic to include measurement values and post here
Threshold SA/4e & Threshold FET 10 hl Lars Erik Ringen Solid State 0 29th October 2013 12:53 PM
Threshold! kekropas Pass Labs 16 29th August 2013 02:16 PM
Threshold canzca Pass Labs 1 4th May 2008 11:27 PM
threshold and t.o.a.o pic Duck-Twacy Pass Labs 3 29th January 2007 10:37 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
