Old 25th January 2004, 11:50 AM   #1
Fuling is offline Fuling  Sweden
Default Is this a choke loaded Xsoz?
Since I donīt have any idea of what I have created (mentally), I must ask for advice here. Would this qualify as a choke loaded XSOZ with CCS "tail"?? Would it even work??
BTW: Sorry for the lousy quality
Old 25th January 2004, 04:30 PM   #2
I hate to sound desperate, but cīmon, I know there is a lot of wise men here who fiddles with amplifier circuits all day, someone must have some comment on this?
Old 25th January 2004, 05:43 PM   #3
Henrik is offline Henrik  Denmark
Hi Fuling
I had this in my "drawer".
It is not a finetuned circiut, but it is close to your scematic.
You need some resistors over the cockes to stabilize them - Nelsons idea.
And the inductors shoud be one inductor with a centertab. This way they are locked to each other through the magnetic field, so when one is going down the other is going up - Circlotrons idea.
Regards Henrik
Henrik
Old 25th January 2004, 08:41 PM   #4
Circlotrons idea
No offense to neither you or Circlotron, but I believe that is whatīs called Push Pull in the tube world. Still a good idea though, especially since I happen to have a pair of homewound chokes that should fit.
I also have a bunch of bigger chokes but Iīll save them for my balanced SE follower (schematic is somewhere else on this forum).
At least ītil this design has been tested properly.
Some resistance across the chokes might be a good idea, even though I havenīt noticed any need for it in my earlier experiments.
If resistance is not enough I guess RC networks would be, a quite common sight around the OPTīs in tube amps.
BTW, is there any reason for the negative rail voltage to be as high as the positive? As far as I can see all the voltage swing takes place in the positive rail (so to speak), so maybe the negative voltage could be reduced drastically?
Old 26th January 2004, 08:46 AM   #5
Circlotron's Avatar
Default You're both right, really.
If I was making a voltage amplifier + phase splitter then I would definitely use a single centre-tapped winding because the outputs are referenced to earth so they *must* be balanced.
For an output stage I would use separate DC biased chokes as per Fuling's cct because the floating load speaker gets driven from the *difference* of the two fet drains, i.e. it is not ground referenced. Hopefully, this will lead to near cancellation of even order harmonic distortion. Besides, this will mean that each fet gets negative feedback from itself only, not from itself in parallel with the other one. Seems tidier to me.
I like that cct Fuling, with the ccs in the tail. I wonder if the tube guys have tried it? I think -5v should be enough for the ccs.
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Old 26th January 2004, 10:45 AM   #6
So, CT chokes for gain stages and separate airgapped chokes for output followers?
Of course it would be easier to design a symmetric PSU, but if we can cut down the idle dissipation with 60W by going from -15 to
-5V Iīd definitly do it!
Old 29th January 2004, 09:33 PM   #7
I understand the the choke symbols on the outputs. But, what is the little box at the other end?
Paul
Old 30th January 2004, 02:30 AM   #8
eLarson is offline eLarson  United States
eLarson's Avatar
The constant current source? Or the resistors (euro-style symbol)?
Erik
Would a woodchuck bother to chuck MDF?
Old 30th January 2004, 09:32 AM   #9
Itīs supposed to be a constant current source
Old 30th January 2004, 01:44 PM   #10
Thanks. Why not a choke threre too? One problem with SOZ is the large heat sinking. The chokes could reduce size and the work of drilling and tapping bias resistors holes.
How much will the chokes improve efficiency?
I have read posts that bias resistors sounded better than an active current source like mosfets in SOZ. I wonder how the chokes will influence the sound.
Paul
Choke loaded LTP jane Tubes / Valves 6 8th November 2008 02:25 PM
Hum on a choke loaded stage Sandor Tubes / Valves 0 28th April 2007 09:16 PM
Choke Loaded ZenV8 RAM Pass Labs 2 30th September 2006 02:01 AM
Choke Loaded Zen hacknet Pass Labs 17 8th April 2004 05:45 PM
X-SOZ-X-BOSOZ.....choke loaded Magura Pass Labs 23 27th February 2004 04:38 PM
Page generated in 0.11226 seconds (69.92% PHP - 30.08% MySQL) with 11 queries
Copyright Đ1999-2012 diyAudio
