The Aleph Design Reloaded
Old 15th May 2018, 05:27 AM   #401
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
nothing is stopping you , when Revelations are in question
though , that's not Miller cap , more antioscillation thingie
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 15th May 2018, 06:12 AM   #402
sarathssca is offline sarathssca  India
Could you please clarify , I didn't understood ..
I have seen many amps /preamps where input LTP stage is connected to VAS transistor's base/gate and there is a capacitor connected to base and collector of VAS transistor .. in explaination it was given to be for handling Miller effect at high frequencies ..
But in any of the aleph circuits or in ba-1 or ba-2 circuits, I haven't seen any such capacitor on the VAS MOSFET ..
Could you please give some inputs regarding this ..
Old 15th May 2018, 06:49 AM   #403
Zen Mod's Avatar
well , being aware that I'm not even a deck-boy on this ship , I'll try .........
it is more matter of looking at Goat - is it better from front , or from back side ?
some amp designers/tweakers are using Miller capacitance term speaking of sort of problems , while other designers/tweakers are using "oscillation" term , addressing their concerns/intentions ...... while ,evidently, family of exact same cures is used in practice
however , Miller capacitance , at least to my understanding, is brought when frequency linearity is objected , while oscillations is used when "amplification phase" is of primary concern thus overall gain stability
stability per se , when circuit is translated from paper to physical world , is complemented with actual physical layout (pcb , wires etc.) so , in s some cases , Papa was able to squeeze through without compensations , with amp having more than enough clean phase behavior , while - in some other cases - phase compensation was/is necessary
explanation can be , probably , found in overall simplicity of his amps (read - minimal number of stages), and in fact that he's either talented , or versed , or both - in solving PCB puzzles
Old 15th May 2018, 09:53 AM   #404
juanitox is offline juanitox  France
juanitox's Avatar
to play with the stock aleph 3 bias is it R113 to replace with a variable resistor ? what value ?
French is not a crime.
Old 15th May 2018, 10:27 AM   #405
Zen Mod's Avatar
here is all info you need
Old 15th May 2018, 02:12 PM   #406
juanitox's Avatar
thank you Zen , if it"s the Pimp my aleph thread is it better to use a special fast/soft recovery bridge with simple C filter or leave the stock one ?
Old 15th May 2018, 04:30 PM   #407
MEGA_amp is offline MEGA_amp
MEGA_amp's Avatar
R105...is the change to 3.3K applicable to 2SJ313 inputs only, or can you use it with IRF9610 as well? Does the change to 3.3K from the usual 10K in Aleph schematics a function of the rails, or can you apply it to all Alephs? I've simulated various R105 (3.3K, 10K, 2K, 1K), and found there isn't much of a change in mA of the current source. Just trying to understand this partiular change.
John
Old 15th May 2018, 04:40 PM   #408
Zen Mod's Avatar
Papa explained that - in some specimens there was too much zener noise with original value
Old 15th May 2018, 04:49 PM   #409
MEGA_amp's Avatar
Doesn't adding a cap across the zener solve the issue?
Old 15th May 2018, 06:32 PM   #410
Zen Mod's Avatar
you can do both
however ...... combined with whoknowswhich RC constant in PSU , up from some value of C , it can slow ramp up of CCS and induce plop! in speaker during powering on
so , try and tweak , if needed
The Aleph Design ReloadedHide this!Advertise here!
Phonic P8A reloaded wxn Multi-Way 5 11th October 2015 12:11 PM
Small Thor -Reloaded -First build 8ntractor Multi-Way 106 19th December 2012 11:00 PM
Va rating reloaded Shelah Solid State 23 5th November 2012 11:36 PM
ZD5 Reloaded. zdr Multi-Way 23 1st February 2011 07:04 AM
Name these soundtracks (Matrix Reloaded and F&F) VEC7OR Music 5 19th July 2003 02:32 AM
