Citation MF12 Equivalent Components - diyAudio
Old 7th January 2015, 01:10 PM   #1
Default Citation MF12 Equivalent Components
Hi all,
I've decided to build the Citation Mosfet 12. I just have a couple of component related questions
I can get IRFP264's at a really good price so I'm thinking of going with these.
In terms of drivers:
I can get 2n5401 for the P types. I can get 2SA970's but they cost around 30x more than the 5401's ( is it worth the extra cost? )
I want to use 2n5550 for the N types since these are complementary to the 5401. I can't get a complementary 2sc for the 970's!
Any Thoughts?
I designed my own set of boards to fit a standard 40mm square aluminium tubing that is readily available here. The other great thing about this is I can press fit a small 40mm DC fan for forced cooling!
Mark
Old 7th January 2015, 02:01 PM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
drivers , go for cheaper ones
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 7th January 2015, 02:40 PM   #3
Thumbs up Cheap Drivers
great 2n5550 and 2N5401 it is then they're about 10 U.S. cents a piece
Old 10th January 2015, 11:11 AM   #4
Default Mica Cap Alternatives
Ok,
So what do you guys recommend as an alternative to the Mica Caps specified in the Citation MF12 Schematic?
Mark
Old 10th January 2015, 11:21 AM   #5
Zen Mod's Avatar
either mica ........... or whatever you can find instead
Old 10th January 2015, 12:20 PM   #6
I can get Mica but only from RS components here and it's a little pricy! is it worth the expense?
Old 10th January 2015, 12:35 PM   #7
Zen Mod's Avatar
if you are just playin' , no
if you are making definitive version of amp ...... planning to use it several years ..... yes
Old 11th January 2015, 06:17 AM   #8
You could have a problem using the IRFP264. The IRF100 has a Ciss ( this is the input capacitence ) of 600pf but your IRFP264 has a Ciss of 5400pf ! That is likely to high for that front end to drive.
Old 11th January 2015, 10:15 AM   #9
Ok I'll use IRFP240's these seem to have the lowest input capacitance of what I can find here.
thanks for pointing that out
As for the Silver Mica caps, turns out they're not easy to come by here, I've found the general replacement for these is class1 multilayer ceramics. These however are all Surface mount and only rated at 50V
Old 11th January 2015, 10:35 AM   #10
Zen Mod's Avatar
good enough
Citation V pdjacob Swap Meet 3 16th February 2012 03:07 AM
citation 7.1 mr l Solid State 30 24th September 2011 02:41 AM
Where Citation name comes from? Eccu Pass Labs 5 25th June 2010 11:51 AM
MF12 Comp PCB's Cambe Solid State 1 26th May 2006 06:30 PM
H/k Citation 7.0 xpablo Digital Source 0 30th December 2004 09:33 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
