10w Xsoz
10w Xsoz
Old 4th April 2004, 02:41 PM   #101
finwbu is offline finwbu  Finland
finwbu's Avatar
10w Xsoz
Default blower-controll
you need no trick, only change C1 .
regards walter
Old 6th November 2004, 10:24 AM   #102
Tyimo is offline Tyimo  Hungary
Default 1 ohm resistors?
Hi!
Mad K and Henrik! I saw your schematics of the XSOZ variations and I would like to ask is it realy possible to leave out the R5-6-7 1Ohm power resistors from the circuit? I saw that you leave out even the wire connection between R3 and R4? Could you tell me why is this better and is it also possible with the original SOZ?
What is the consequence if I use higher value resistors for R1-2-3-4? I mean over 8 ohms?
Thanks!
Old 7th November 2004, 08:50 AM   #103
Henrik is offline Henrik  Denmark
Hi Tyimo
R7 in the original SOZ keeps the gain down.
When you apply X to soz you loose some gain caused by the feedbackloop.
By shorting R7 you get max gain from the diffpair.
When R7 is shorted it means that R5 and R6 is coupled in parallel and is then considerd as one resistor at 0.5 Ohm.
R3 an R4 is also parallel and as such works as one resistoer at 4 Ohm.
R5/6 and R3/4 is coupled in series wich mens they operate as one resistor at 4.5 Ohm when R7 is shorted.
If you use greater values, you primarily looses some power.
Henrik
Old 7th November 2004, 05:10 PM   #104
Thanks Henrik!!
What about to use 12 Ohm instead of the 8.5R? How many power would I loose? How can I calculate it?
10w XsozHide this!Advertise here!
Some kinda XSoZ Fuling Pass Labs 9 27th June 2004 07:17 PM
XSOZ/Complementary Zen heat sinking question needtubes Pass Labs 5 5th April 2004 09:28 PM
quick heatsink question for 5w XSOZ enochRoot Pass Labs 7 21st March 2004 07:23 PM
Is this a choke loaded Xsoz? Fuling Pass Labs 10 31st January 2004 12:20 PM
