Problems when starting up F5.
Old 19th December 2014, 10:54 PM   #1
PMA! is offline PMA!
Default Problems when starting up F5.
Hi!
My friend has copied my F5 builds (CLC input filter, dual mono).
I was over at his house helping him with the start up procedure, and everything was going well until we were starting to turn up the juice (adjusting the bias and offset).
I noticed that turning the variable resistors had little effect on the voltage reading across R7\R8. The offset (measuring voltage across speaker terminals) responds normal to adjustment of the resistors, but when I reached a reading of ca. 30 mV across R7\R8 the resistors had reached their end point.
We have tripple checked every resistor position and value. We have checked all positions and directions of transistors. We were getting tired at the end, but we must be missing something quite obvious?
He has built two amps. Both amplifier sides of both amps behave in the same way.....Help?
Old 20th December 2014, 04:15 AM   #2
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Idss of input Jfets ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 20th December 2014, 09:07 AM   #3
He bought grade a or b from the diyaudio store...
Old 20th December 2014, 09:14 AM   #4
R.I.P.
measure the Idss of the jFETs. (a DMM + 9V battery + 100r is all you need to get an approximate value).
measure the voltage across the drain load of the jFETs.
measure the output source resistor Vdrop.
regards Andrew T.
Old 20th December 2014, 11:23 AM   #5
Could you give me further instructions of how test this up? Thanks!
Old 20th December 2014, 11:34 AM   #6
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
If you do a search for "matching fets" you will see how it's done.
Old 20th December 2014, 05:39 PM   #7
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Looks like you need to increase the value of the load resistance between
the supplies and Drains of the input devices. As there is a resistor in parallel
with each pot on stock versions, you can increase the value of those resistors.
Old 20th December 2014, 11:16 PM   #8
haato is offline haato  Norway
Thank you for your answer, PMA is helping me out. I have changed the resistor (R3 and R4) in parallel with each pot from 2K2 to 4K7. Before the switch I reached 30 mV. I now get 180mV across the R7\R8 resistors before the variable resistors (P1 and P2) reached their end point.
What value should I choose for R3 and R4 to reach the final goal of 590mV?
Old 21st December 2014, 01:44 AM   #9
Zen Mod's Avatar
try 6K8
I asked for Idss .... in that case you would be served with precise answer
Old 21st December 2014, 09:26 AM   #10
The LSJ74A should have Idss min 2,6mA max 6,5mA. The LSK170A should have Idss min 2,6 mA and max 6,5 mA. I bought them from the DIYAudio store.
I`m quite new to DIY, thank you for all your help. Hope I will have the amp`s up and running for Christmas.
Problems when starting up F5.Hide this!Advertise here!
Starting to build my first F5 Turbo V3 2bz Pass Labs 96 13th October 2015 06:46 AM
F5 bias problems IZHAKKATZ Pass Labs 14 27th March 2013 01:32 PM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 problems Flemming J P Pass Labs 15 14th April 2012 01:37 AM
Just starting to learn o-scope, F5 1k square looks funny JZatopa Pass Labs 24 25th March 2012 07:48 AM
